Problem : creating a vertical plane with rotation
JiPe38
Postby JiPe38 » Wed Jan 22, 2020 11:08 am
OS: Windows 10 (10.0)
Version: 0.19.19311 (Git)
Hash: 120b69c74f7dac8c4fa6dbc0a7e10674bde9216c
Python version: 3.7.3
Qt version: 5.12.5
Locale: French/France (fr_FR)
Dear PartDesign developers
I have a problem in a design. I have a symetry on axis z on my design (a cylindre). I want to create a vertical plane on the cylindre axis and rotate it of 45°.
So I ask to create a plane and choose XZ object plane as attachment. I thought that I could later change the placement of this plane to ask a rotation of 45° on the z axis. Impossible... there is already a rotation in the placement, which is computed by FC to rotate the xy plane and send it in the position of the xz plane !
Would it be possible to change this in such a way that a plane created on xz plane appears in the placement adjusting dialog has having 0° rotation angle, in order to let the user adjust it by a rotation on any x, y or z axis ?
openBrain
Re: Problem : creating a vertical plane with rotation
Postby openBrain » Wed Jan 22, 2020 12:47 pm
First as I already told to you, this kind of discussion shall go the the Help subforum.
Then there is no need for change.
In PartDesign, the attachment locks the Placement, and the AttachmentOffset property is created so you can further move/rotate the object.
In any case, you click on AttachmentOffset value (or Placement value if you're out of PartDesign) then click an the 3-dot button that appears at the right of the cell. There you can choose 'Apply incremental changes'. ;)
JiPe38
Postby JiPe38 » Wed Jan 22, 2020 2:57 pm
I try reproduce the conditions of this problem. Here is a simplified design.
testXZ.FCStd
(11.88 KiB) Downloaded 2 times
I create a datumPlane, selecting to attach on XZ plane.
I get this : the plane is visible on the XY plane instead of XZ.
I said "oops there must be a bug, I can't attach on XZ plane". Oddly, it's marked attached XZ in the left panel.
So I attempt to place my vertical plane using a trick. I select an edge on the rectangular pad of my design.
I choose to attach the datum plane on the inertial 2-3 axes of this edge and I get the right position (XZ) of this plane.
I thought that it was ok, and that I could then rotate this vertical plane to get it in the wished 45° position. But I can't change the positions of the plane because they have been fixed by FC with a 120° angle and an odd axis, to I can't modify this rotation if I don't want to compute an inversion and a product on 3x3 matrices on a spreadsheet, which could take me hours !
So, perhaps the problem comes from a misunderstanding of FC and PD interfaces. It seemed to me so straightforward to choose to create a datumPlane on the XZ object plane and then rotate it according to my needs. I suppose that a trained user could tell me that neither of the two attempts explained here should be used and that the right way of doing things is... Well, perhaps there is a bug somewhere. I don't know.
JiPe38
Postby JiPe38 » Wed Jan 22, 2020 3:12 pm
Edit : What a mess : images come in reverse order of their insertion in the text, all placed after.
openBrain
Postby openBrain » Wed Jan 22, 2020 3:25 pm
Actually you selected an Attachment Mode (Object's XY) but no reference object, so it can't work.
See below 2 ways to get a Datum Plane on XZ Plane. ;)
Nota : I saw a bug on the 2nd method if Origin items aren't made visible before launching the task. I'll open a specific ticket.
JiPe38
Postby JiPe38 » Wed Jan 22, 2020 6:17 pm
OK thanks. First method is simple and OK. Not documented in the wiki and my "too fast" method not signaled as an error in the python console :(
Second method : I will see later. Glad if I could help, unwillingly, to show a real bug.
openBrain
Postby openBrain » Wed Jan 22, 2020 6:34 pm
Once picture is downloaded, you can insert it in the text with 'inline' button. ;)
No real bug here. You select no reference -> your datum plane is not attached. This is even told to user by the small purple icon you see in the Tree View (in your pictures, overlaid with the datum plane icon).
JiPe38
Postby JiPe38 » Wed Jan 22, 2020 6:47 pm
The one for which you want to open a ticket.
JiPe38
Postby JiPe38 » Wed Jan 22, 2020 6:57 pm
Just for information, if somebody follows this path. After creating the plane attached to XZ, to rotate it on the Z axis of the body, in the "placement" dialog box, axis Y must be set as the rotation axis. I suppose the rotation is defined relatively to the plane's axes instead of those of the body.
So, to insert an image inside a text, better not to click the "insert image" button...
openBrain
Postby openBrain » Wed Jan 22, 2020 7:36 pm
