Trim caused "program not responding" crash (WinXP)
NormandC
Re: Trim caused "program not responding" crash (WinXP)
Postby NormandC » Tue Jul 23, 2013 5:19 pm
That would have to be discussed with the developers. But it's been that way since the beginning of FreeCAD, I'm not sure they'll be willing to change it.
oldestfox
Postby oldestfox » Tue Jul 23, 2013 5:22 pm
Thanks. I'll post it in Mantis BT.
Site Admin
Postby wmayer » Wed Jul 24, 2013 8:50 am
Do you think it would be a big deal to have the numerical sequence, 0-6, match the positional sequence of the associated icons in the toolbar? That would be so much more intuitive. Or has that been brought up before?
Sorry, but this isn't possible because these shortcuts are already used by the standard view commands.
oldestfox
Postby oldestfox » Wed Jul 24, 2013 12:52 pm
As was noted in MantisBT #1189, re-arranging the icons would work. Too bad "customize" doesn't work. Any idea when that function may be operational?
Site Admin
Postby wmayer » Wed Jul 24, 2013 2:07 pm
Ah, now I see what you mean. First, I thought you wanted to use these shortcuts for the sketcher commands. OK, that's easy to fix.
Musti
Postby Musti » Tue May 06, 2014 8:51 am
I have observed the same error on FreeCad 0.13 on Windows 7. The attached file should reproduce the error every time, when you try to trim the circle to the adjoining square, see the screenshot how the trim should be made. After clicking on the segment the program hangs, no excessive processor usage or similar.
rail.FCStd
(11.03 KiB) Downloaded 22 times
Site Admin
Postby wmayer » Tue May 06, 2014 4:14 pm
Can you be a bit more verbose of what steps I have to run to make FreeCAD hanging, please?
jmaustpc
Postby jmaustpc » Tue May 06, 2014 5:30 pm
Musti wrote:I have observed the same error on FreeCad 0.13 on Windows 7. The attached file should reproduce the error every time, when you try to trim the circle to the adjoining square, see the screenshot how the trim should be made. After clicking on the segment the program hangs, no excessive processor usage or similar.
Have you possibly uploaded the wrong file? The sketch in this file already had the circle trimmed to the square.
hyperg
Postby hyperg » Wed May 21, 2014 11:39 am
I've encountered the same issue recently, but the OS is Win7 x64, not XP. I've attached the sketch causing the issue. The hang occurs when I try to trim the horizontal edge right under the arc on the left (it might do the same with the right one though).
I've re-drawn the same shape with a different grid/snap setting (1mm instead of 0.5mm) and the trim works in that case. The hang seems to happen only when the arcs have a radius of 1.5mm
Hope this helps,
Thanks.
HangTest.FCStd
(2.87 KiB) Downloaded 28 times
bejant
Postby bejant » Wed May 21, 2014 3:02 pm
HangTest took over 18 minutes with one core maxed out at 100% and the other 60 - 70% usage! I did have other processes running but nothing CPU intensive.
OS: Ubuntu 12.04.4 LTS
Platform: 32-bit
Version: 0.14.3620 (Git)
Hash: bff814b73a0dd469e8a58fd1d7c21852b421b1ea
Python version: 2.7.3
Qt version: 4.8.1
Coin version: 3.1.3
SoQt version: 1.5.0
OCC version: 6.7.0
