[?BUG] Addon Manager hangs in 0.19 on MacOS and possibly related issues.
duncandoo
Postby duncandoo » Mon Jan 27, 2020 8:11 pm
Since installing 0.19 on MacOS, the Addon Manager just hangs. The Addon Manager in 0.18 works just fine. I've attached everything I can find, but can't figure this out. You'll see there are some other errors, which may give clues, and may or may not be separate bugs. Again, would be pleased to sort these out, do advise whether I should start separate discussions about these.
Steps to reproduce:
1. run FreeCAD
2. click Menu>Tools>Addons Manager
3. wait, wait, wait......
Screen Shot 2020-01-27 at 17.42.00.png (57.39 KiB) Viewed 1303 times
It remains like this forever, over an hour at least.
...but
4. click Macros
Screen Shot 2020-01-27 at 17.42.19.png (120.58 KiB) Viewed 1303 times
Version:
OS: macOS High Sierra (10.13)
Version: 0.19.19323 (Git)
Hash: 1b198453b8eb6aa2eaca4e4be4b49fee74e9de6e
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Error Messages
Running from the terminal yields:
FreeCAD 0.19, Libs: 0.19R19323 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2020
Geodat WB: Cannot import module named cv2
Geodat WB: Cannot import module named gdal gdalconst
During initialization the error "'backend.qt4 is not a valid rc parameter (see rcParams.keys() for a list of valid parameters)'" occurred in /Applications/FreeCAD.app/Contents/Resources/Mod/Animation-master/InitGui.py
Please look into the log file for further information
During initialization the error "'backend.qt4 is not a valid rc parameter (see rcParams.keys() for a list of valid parameters)'" occurred in /Users/duncan/Library/Preferences/FreeCAD/Mod/animation/InitGui.py
GVA error: Not detecting IGPU in IORegistry!
GVA error: Not detecting valid offline codec!
GVA info: Successfully connected to the Intel plugin, offline Gen6
Log file:
Here's the log file. I made two log files, one just opening and closing FreeCAD, the other, attached, opening FreeCAD, opening Addon Manager and then closing. They are exactly the same file, apart from timestamp.
freecad4.log
(16.36 KiB) Downloaded 17 times
Thanks for any help you can give.
Meru
Re: [?BUG] Addon Manager hangs in 0.19 on MacOS and possibly related issues.
Postby Meru » Sat Feb 01, 2020 3:17 pm
The same here:
OS: macOS 10.15
Version: 0.19.19405 (Git)
Hash: d2b943e8b7d8fe2673a4e20671b6cb0f8180fdbd
Qt version: 5.12.5
OCC version: 7.4.0
Gruß M
vocx
Postby vocx » Sat Feb 01, 2020 5:24 pm
You seem to need "cv2" and "gdal" packages to be able to install the Geodat workbench.
There are some warnings about missing backends for Qt4 for the Animation workbench. And you have two such workbenches, one called, "Animation-master", and another one called "animation".
I would manually delete these folders, and try to re-install.
rm -rf /Applications/FreeCAD.app/Contents/Resources/Mod/Animation-master/
rm -rf /Applications/FreeCAD.app/Contents/Resources/Mod/animation/
steve123
Postby steve123 » Sat Feb 01, 2020 7:00 pm
I am having the same problem. My log is clean (no errors). Add-on manager does not list the workbenches but it does list the macros.
OS: macOS Mojave (10.14)
Qt version: 5.12.5
OCC version: 7.4.0
Postby chrisb » Sat Feb 01, 2020 11:34 pm
Moved from Developers forum.
Postby chrisb » Sat Feb 01, 2020 11:39 pm
I can confirm. I tested with a plain vanilla config directory. No messages on startup, no messages when calling Addon manager. The list of workbenches stays empty, not hanging. Macros are ok.
Qt version: 5.12.5
OCC version: 7.4.0
looo
Postby looo » Sun Feb 02, 2020 5:21 am
Did the addon-manager work with any of the py3.8 builds?
Postby chrisb » Sun Feb 02, 2020 7:11 am
No.
looo
Postby looo » Sun Feb 02, 2020 6:23 pm
No.
I have no access to the mini until 12.02. If you find any hints on how to solve the problem please report back.
Postby chrisb » Mon Feb 03, 2020 6:39 pm
I should be able to narrow this down. I tried for now the brute force method of copying an old version of Mod/AddonManager - and it works!
