[?BUG] Addon Manager hangs in 0.19 on MacOS and possibly related issues.
duncandoo
Post by duncandoo »
Since installing 0.19 on MacOS, the Addon Manager just hangs. The Addon Manager in 0.18 works just fine. I've attached everything I can find, but can't figure this out. You'll see there are some other errors, which may give clues, and may or may not be separate bugs. Again, would be pleased to sort these out, do advise whether I should start separate discussions about these.
Steps to reproduce:
1. run FreeCAD
2. click Menu>Tools>Addons Manager
3. wait, wait, wait......
Screen Shot 2020-01-27 at 17.42.00.png (57.39 KiB) Viewed 3024 times
It remains like this forever, over an hour at least.
...but
4. click Macros
Screen Shot 2020-01-27 at 17.42.19.png (120.58 KiB) Viewed 3024 times
Version:
OS: macOS High Sierra (10.13)
Version: 0.19.19323 (Git)
Hash: 1b198453b8eb6aa2eaca4e4be4b49fee74e9de6e
Python version: 3.8.1
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Locale: C/Default (C)
Error Messages
Running from the terminal yields:
FreeCAD 0.19, Libs: 0.19R19323 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2020
Geodat WB: Cannot import module named cv2
Geodat WB: Cannot import module named gdal gdalconst
During initialization the error "'backend.qt4 is not a valid rc parameter (see rcParams.keys() for a list of valid parameters)'" occurred in /Applications/FreeCAD.app/Contents/Resources/Mod/Animation-master/InitGui.py
Please look into the log file for further information
During initialization the error "'backend.qt4 is not a valid rc parameter (see rcParams.keys() for a list of valid parameters)'" occurred in /Users/duncan/Library/Preferences/FreeCAD/Mod/animation/InitGui.py
GVA error: Not detecting IGPU in IORegistry!
GVA error: Not detecting valid offline codec!
GVA info: Successfully connected to the Intel plugin, offline Gen6
Log file:
Here's the log file. I made two log files, one just opening and closing FreeCAD, the other, attached, opening FreeCAD, opening Addon Manager and then closing. They are exactly the same file, apart from timestamp.
freecad4.log
(16.36 KiB) Downloaded 76 times
Thanks for any help you can give.
Meru
Re: [?BUG] Addon Manager hangs in 0.19 on MacOS and possibly related issues.
Post by Meru »
The same here:
OS: macOS 10.15
Version: 0.19.19405 (Git)
Hash: d2b943e8b7d8fe2673a4e20671b6cb0f8180fdbd
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Gruß M
vocx
Post by vocx »
duncandoo wrote: Mon Jan 27, 2020 8:11 pm Running from the terminal yields:
You seem to need "cv2" and "gdal" packages to be able to install the Geodat workbench.
There are some warnings about missing backends for Qt4 for the Animation workbench. And you have two such workbenches, one called, "Animation-master", and another one called "animation".
I would manually delete these folders, and try to re-install.
rm -rf /Applications/FreeCAD.app/Contents/Resources/Mod/Animation-master/
rm -rf /Applications/FreeCAD.app/Contents/Resources/Mod/animation/
steve123
Post by steve123 »
I am having the same problem. My log is clean (no errors). Add-on manager does not list the workbenches but it does list the macros.
OS: macOS Mojave (10.14)
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
Moved from Developers forum.
I can confirm. I tested with a plain vanilla config directory. No messages on startup, no messages when calling Addon manager. The list of workbenches stays empty, not hanging. Macros are ok.
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
looo
Post by looo »
Did the addon-manager work with any of the py3.8 builds?
looo wrote: Sun Feb 02, 2020 5:21 am Did the addon-manager work with any of the py3.8 builds?
No.
looo
Post by looo »
chrisb wrote: Sun Feb 02, 2020 7:11 amNo.
I have no access to the mini until 12.02. If you find any hints on how to solve the problem please report back.
I should be able to narrow this down. I tried for now the brute force method of copying an old version of Mod/AddonManager - and it works!
