[?BUG] Addon Manager hangs in 0.19 on MacOS and possibly related issues.
Re: [?BUG] Addon Manager hangs in 0.19 on MacOS and possibly related issues.
Postby chrisb » Mon Feb 03, 2020 10:35 pm
I finally found the culprit: If I change line 43 in addonmanager_utilities.py from
        ssl_ctx = ssl.create_default_context(ssl.Purpose.SERVER_AUTH)
to
        ssl_ctx = ssl.create_default_context(ssl.Purpose.CLIENT_AUTH)
AddonManager shows the list of workbenches again.
I don't understand the implications, so I don't know what to do. Should I create a pull request?
looo
Postby looo » Tue Feb 04, 2020 10:45 am
nice! I tested with windows and linux and the addon-manager works for both with the mentioned change. So please go ahead and create a PR.
Maybe apply the change only for py3.8.
if sys.version_info.major >= 3 and sys.version_info.minor >= 8:
else:
easyw-fc
Postby easyw-fc » Tue Feb 04, 2020 11:12 am
@chrisb is asking if this would change something about how the SSL is handled... it seems client certificates don't encipt data...
No encryption of data takes place in case of Client certificates.
looo
Postby looo » Tue Feb 04, 2020 11:44 am
And this s a problem?
easyw-fc
Postby easyw-fc » Tue Feb 04, 2020 1:02 pm
in terms of privacy yes...
moreover we should discover why the server side option is working on Win and Linux but not on OSX...
Postby chrisb » Tue Feb 04, 2020 1:22 pm
Can I do something to narrow this down?
looo
Postby looo » Tue Feb 04, 2020 2:38 pm
[/quote
Maybe trying to reproduce the error directly with a conda-environment (not the bundle).
easyw-fc
Postby easyw-fc » Tue Feb 04, 2020 5:12 pm
this is reminding me an issue I had with AppImage which is now solved ... this is not instead solved on OSX bundle
We failed to reach a server.
Reason: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1108)
EDIT:
https://forum.freecadweb.org/viewtopic. ... 20#p327416
Postby chrisb » Wed Feb 05, 2020 10:42 pm
It seems to be rather a MacOS issue than a Python 3.8 one. It seems that Apple has stopped supporting openSSL. It needs to be compiled which needs to install at least some xcode packages ...
I would prefer to make the distinction which authentication to use depend on the OS.
I could use one of these:
platform.system() which is on my system 'Darwin'
sys.platform which is on my system 'darwin'
platform.platform() which is on my system 'macOS-10.13.2-x86_64-i386-64bit'; I would use the first 5 characters for comparison.
Which one is the right way to go? Or should I use something else?
triplus
Postby triplus » Wed Feb 05, 2020 11:09 pm
That is i guess one of the cons of using the latest versions of software, as you get to fix the new bugs. ;)
