[BUG + crash] ?!?- Thickness on pipe element
m.cavallerin
Postby m.cavallerin » Sun Feb 02, 2020 3:45 am
if I add a thickness function to a pipe element built with sweep, the program fails.
And If a set make it inwards FC crashes.
Cheers Michele
Sweep1.FCStd
(17.38 KiB) Downloaded 10 times
Screenshot from 2020-02-02 04-44-06.png (62.89 KiB) Viewed 211 times
Re: [BUG + crash] ?!?- Thickness on pipe element
Postby chrisb » Sun Feb 02, 2020 6:57 am
(Moved from PartDesign development forum where you should post if you contribute to developing that workbench)
Thickness is one of the most picky functions in FreeCAD, yet the issues come from the OCC geometric kernel used and FreeCAD developers cannot do much about it.
Nevertheless FreeCAD should not crash. Please retry with a current 0.19. If the crash persists, attach your full FreeCAD info as described in the IMPORTANT forum rules linked above.
Edit: Outward thickness works here, but I can confirm the crash on inwards thickness.
OS: macOS High Sierra (10.13)
Version: 0.19.19405 (Git)
Hash: d2b943e8b7d8fe2673a4e20671b6cb0f8180fdbd
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Postby chrisb » Sun Feb 02, 2020 7:04 am
Please make the tests mentioned above anyway, as it may be interesting for the developers to know if the crash is system dependent. But you can achieve your goal by using a different profile for sweep, such as
Snip macro screenshot-c96ef8.png (4.69 KiB) Viewed 195 times
GlouGlou
Postby GlouGlou » Sun Feb 02, 2020 8:23 am
Bends are very tight in relation to the pipe diameter. You should use "round corner" option to help Freecad. ;)
openBrain
Postby openBrain » Sun Feb 02, 2020 8:32 am
Can confirm crash when making thickness inward. Unfortunately I guess this comes from OCC (despite we maybe could handle that).
However issue is quite understandable. In your pipe, you're using a 20 mm radius circle as profile while the path contains 20 mm radius arcs. This creates kind of 'superimposed' edges intersection that are then complex to handle.
You can just test using eg. a 15 mm radius for the profile and then everything goes well. ;)
m.cavallerin
[SOLVED] - Thickness on pipe element
Postby m.cavallerin » Thu Feb 06, 2020 5:35 am
Sorry for late reply, but the post has been moved and I thought it has been deleted...in any case:
Yes, indeed it was a fault on bending radius; setting it to the value of 20,001mm (or higher) with outder diametr equal to 20mm, the function works properly.
thx.
Michele
openBrain
Re: [SOLVED] - Thickness on pipe element
Postby openBrain » Thu Feb 06, 2020 12:30 pm
You can always find your posts on Tools->My Post on top of the page. ;)
Correct. But a crash always should be prevented as it can lead to data loss. Guys, agree with that and that it deserve a ticket ?
Postby chrisb » Fri Feb 07, 2020 8:24 am
Yes.
openBrain
Postby openBrain » Fri Feb 07, 2020 1:15 pm
