What is the real reason why Body001->AdditiveLoft can not be mirrored over the DatumPlane, through Part Design -> Create Mirror feature?
OS: openSUSE Tumbleweed
Version: 0.18.Unknown
Python version: 3.7.3
Qt version: 5.14.0
Coin version: 3.1.3
mirrored additive loft
- HDD enclosure.FCStd
- (69.11 KiB) Downloaded 21 times
Re: mirrored additive loft
It's the one solid rule.
so the mirrored thing supposed only to form one solid?
- papyblaise
In Partdesign you can only use miror in the same body , so you have 2 bodies
the only possibility is use miror from Part Wb
But i use mirror on the thing from only the Body001papyblaise wrote: ↑Sat Feb 08, 2020 12:57 pm In Partdesign you can only use miror in the same body , so you have 2 bodies
A body should always produce in a single solid. In your case the mirror operation results in two separate solids and this is not allowed.
Thanks!
