Problem when carrying out the sweep
mitu7362
Postby mitu7362 » Wed Feb 12, 2020 8:27 am
Hello everyone,
I have encounterd a problem when I try to make the extension spring by using the sweep.
For some reasons I have to keep the spiral line of the spring in segments, just like what it is when I try to generate the spiral line using the GUI. However, the error "spine is not connected " always appears and the sweep is faild, but I cannot find any broken points. What interesting is, when I change the spiral line to the continuous form by using the python-commands with completely the same parameters, the sweep works without any problems.
What could be the problem? :cry:
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Chinese/China (zh_CN)
Segments.FCStd
(35.09 KiB) Downloaded 7 times
Continuous.FCStd
(73.35 KiB) Downloaded 4 times
Re: Problem when carrying out the sweep
Postby chrisb » Wed Feb 12, 2020 9:04 am
You can try 0.19 or upload your file.
mitu7362
Postby mitu7362 » Wed Feb 12, 2020 2:25 pm
Hello Chrisb.
The FCStd files are in my post. I have tried with 0.19 but it does not help.
openBrain
Postby openBrain » Wed Feb 12, 2020 2:47 pm
Could you give some more details on that ?
Actually he problem I find is that the 'Spine' property of the Sweep (you can see it with right-click on the Property Editor -> Show all) has no edge selected but only an object. Thus it complains that the Spine actually has no edge.
If you create a new sweep and select all individual edges with the mouse, it works correctly.
What I'm interested in is understanding what is exactly your 'continuous' mode so I can investigate why it succeeds in your second file (what I wound not have expected). ;)
mitu7362
Postby mitu7362 » Wed Feb 12, 2020 3:26 pm
Hello openBrain:
At first thanks a lot for the reply. I think these scrennshots explain the two forms that I mean well. Above: Spine in segments. Under: Spine in continuous form.
I have also attached the excerpts of the python-commands for generating the two types of the spiral lines, respectively. Sorry that I cannot upload all of the codes since it is a project that is still ongoing:( .The parameters used in these two excerpts are completely the same.
Excerpt_Segments.py
(675 Bytes) Downloaded 5 times
Excerpt_Continuous.py
(295 Bytes) Downloaded 5 times
Postby chrisb » Wed Feb 12, 2020 10:21 pm
I guess the problem is the numbering of the segments. Hover over them and you will see that they are not connected in consecutive order.
mitu7362
Postby mitu7362 » Thu Feb 13, 2020 10:21 am
Hello Chrisb:
I have found another way to do it so that this problem can be avoided. Anyway thanks a lot.
mario52
Postby mario52 » Thu Feb 13, 2020 10:25 am
hi
continuous complete (Macro_Dxf_To_Shape)
principle discretize all object (verify the direction) save the coordinate part to part and load the complete file and raccord the coordinates
Continuous02.FCStd
(35.03 KiB) Downloaded 5 times
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
mitu7362
Postby mitu7362 » Fri Feb 14, 2020 7:50 pm
hi
Continuous02.FCStd
mario
Hello Mario52:
Thanks a lot for the tips. Will give it a try.
