Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Russian/Russia (ru_RU)
OS: Windows 10 (10.0)
Version: 0.19.19510 (Git)
Hash: c3eb6d9001c4d60ff7f7cae89f50bd3c965a9940
Python version: 3.7.3
Qt version: 5.12.5
a)
Applying Thickness(PartDesign or Part do not mater) will cause a crush, IF a part is made with splines. I was able to produce a reliable test case.
That will crush right after clicking the button.
b)
Apllying thickness to Slot- loft, also crush. Ther is no splines, only lines and arcs.
this will crush
But, if they do not rotated between each other, no too curved walls, then it works ok.
if one of the slots is different size its ok too
here is the files
0.18 only splines lofted 0.19 splines and slots
Part two
One might think that this design will cause crush too? well, no. It will hide part initialy, but if you toggle "Make thickness inwards" few times and tune thickness value a bit, it works. And not only on flat faces, but on curved ones too! Very interesting.
Crushing is totally not ok, but after some googling and reading i came to realization that may be opencascade issue. It known for crushing in case of curved geometry https://tracker.dev.opencascade.org/view.php?id=30003
