Hi i am from fusion 360 user. There i can extrude multipal part from a single sketch. But in freecad i can't able to to that.
the issue is in extrude/pad i can't select the part of the sketch that i want to extrude. it always extrude what it likes, i mean select the sketch it self.
see this pic, i want to to this.
[this][https://imgur.com/MTWlk6k]
1st pic .see there i extrude the bottom part first then i did the current one shown in pic second extrude.
2nd and 3rd one see the sketch and the pad from freecad.
Why there is no way to upload pic here directly?
Multipal extrude/pad from a single skecth
Re: Multipal extrude/pad from a single skecth
You can drag/drop them over the text editing area or use "Attachments" tab under the "Submit" button.
On your main question - this is just the way FreeCAD is designed to act at the moment. You can draw everything in one sketch and then use "Link external geometry" in another sketch to import only the things that you need for that specific feature.
but think about it, there will be so many sketch. And where is the "Link external geometry" thing? any guide for it?kisolre wrote: ↑Tue Feb 18, 2020 6:27 amYou can drag/drop them over the text editing area or use "Attachments" tab under the "Submit" button.
- papyblaise
I can see saveral "auto-intersections" this is cause of crash
do this in2 or 3 times without auto-intersection
- autointersection-1.PNG (16.89 KiB) Viewed 324 times
- autointersection.PNG (10.29 KiB) Viewed 324 times
Sketcher_Externalrahmanshaber wrote: ↑Tue Feb 18, 2020 7:14 am And where is the "Link external geometry" thing? any guide for it?
The same question had been asked not too long ago, please search the forum for the other discussion.
