I've gone through a number of tutorials and forum posts, specifically from https://www.freecadweb.org/wiki/PartDesign_Mirrored, under Usage step 3.5. "Repeat to add other features". From every piece of documentation I should be able to add multiple feature to the mirror or to the MuliTransform however I am not able to. Whenever I press either Add Feature or Remove Feature it only toggles the originally selected feature on and off. I am not able to provide additional features. MultiTransform provides a similar feature, I tried there to and I'm seeing the same issue.
I've generated a, hopefully, simple example: . Steps to create:
- Created a square centered around origin
- Padded it
- On a face I placed a circle (2mm radius) in one corner
- This circle was padded
- On the same face a smaller (1mm radius) circle was placed concentric to the larger
- This smaller circle was pocketed through all
- Finally a chamfer was performed on the outter edge of the cylinder
Seems like a bug, am I just doing something wrong? I realize I could perform the MultiTransform three times and achieve the same feat, but I'm attempting to publish my files (much more advanced then a cube ) and would like to keep them as simple and straight forward as possible.
Version (as far as I can tell this is this latest stable release available...as of posting)
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
