Please see attached file of lofted shapes.
Each were created in the same manner:
Part Design Workbench
1. Create Sketch in XY plane
2. Edit/Duplicate Sketch and rotate about X axis 45 deg via Placement from the Data Tab of Project Box
3. Adjust shape dimensions as required
4. Edit/Duplicate Sketch and rotate about X axis 90 deg in same manner as before
5. Adjust shape dimensions if required
Part Workbench
6. Select three sequential sketches from Loft dialog box and select Create Solid
All of the Lofts seem to behave as expected except one. Note the upper right Loft shape that failed. It seems to be related to the particular combination of arcs and straight lines that form a 'C' section.
Is this a known limitation or am I doing something incorrectly?
[OS: Windows 7 Platform: 32-bit Version: 0.13.1828 Python version: 2.6.2
Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.3.0]
Loft Failure--C shaped profile
- loft_failure.FCStd
- (46.62 KiB) Downloaded 57 times
"It is a poor workman who blames his tools..."
Re: Loft Failure--C shaped profile
Since I did not get any response from the community, I decided to do a little more experimentation and eventually solved my own problem a different way.
I ended up using Sweep instead of Loft.
Please see the attached file showing the difference between loft and sweep for the same profiles. I have yet to find another cross-section other than the 'C' shape that Loft fails in this manner.
- sweep vs loft.FCStd
- (28.79 KiB) Downloaded 53 times
Yesterday I downloaded the file in your first post, and could only replicate the problem but could not solve it. I would not have known to try "Sweep" rather than "Loft" had you not posted your solution; thanks for posting it.ppemawm wrote:I ended up using Sweep instead of Loft.
I was thinking: that still doesn't explain why loft worked in 3 places but not the last.
Is it because loft is the wrong function to use, or is the problem something else?
No, it should work. I have no idea why it doesn't.bejant wrote:Is it because loft is the wrong function to use, or is the problem something else?
I think a developer needs to look at it...
