Ticket #4272 - Pick radius flickering
MuffinChocolate
Postby MuffinChocolate » Sat Feb 22, 2020 1:21 am
I installed Freecad using aptitude, I am running XUbuntu 19.10.
1) New file
2) New sketch
3) Create line
4) Then do what I do in the gif.
Gif see attachments.
PS: I did set the pick radius to 10px, but yes, this occurs with the default setting of 5px as well.
Thanks!
Reason: Added ticket number to thread title
UR_
Re: 0.18.3 - Pick radius flickering
Postby UR_ » Sat Feb 22, 2020 6:35 am
Here too.
OS: Windows 10 (10.0)
Version: 0.19.19694 (Git)
Hash: 288456ee4beb9e8dc27d50a7984c40c45467161f
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
But only if tool selected.
Postby chrisb » Sat Feb 22, 2020 6:45 am
I have realized this for quite some time and it makes auto constraints rather difficult to use. Since Abdullah is currently not around I didn't investigate it any further. I have the feeling that it is not always the case.
MuffinChocolate
Postby MuffinChocolate » Sat Feb 22, 2020 12:22 pm
Thank you for circling in on this UR_.
@chrisb:
I did not find an open bug for this.
I must say, reporting bugs even for someone with software development experience who also reported bugs on other projects is quite cumbersome.
It was difficult to find an issue search mask that does not expect an id but works with keywords.
Then I felt I had to register there so I made an account.
Then a guide says to ask on the forums first.
Couldn't use the credentials here, had to register again.
Didn't find a subforum specifically dedicated to this, so instead I posted here.
It seems to be a rather obvious bug, and I am sure I made a lot of mistakes trying to find a way to report this, but I feel like there must be a huge resistance for others if I am the only one that ended up here.
Postby chrisb » Sat Feb 22, 2020 1:30 pm
It is perfectly correct to discuss errors here first. Even if you and I think something is a bug, others may not or have already a solution in the queue or may tell you that the bug cannot be fixed by a FreeCAD developer, because it comes from one of the third party libraries, or there is an easy workaround.
What we see in most cases is no bug at all, but rather user errors.
And finally, and this is very important, you make the error known to the community and others can help accordingly.
MuffinChocolate
Postby MuffinChocolate » Sat Feb 22, 2020 2:11 pm
What else can I do at this point? Anything you want me to try or supply?
openBrain
Postby openBrain » Sat Feb 22, 2020 2:23 pm
I you have ability to do so, you can investigate starting from this point. ;)
triplus
Postby triplus » Sat Feb 22, 2020 3:17 pm
Disco mode?
MuffinChocolate
Postby MuffinChocolate » Sat Feb 22, 2020 8:17 pm
Okay, I have managed to compile freecad and do a bit of very primitive debugging.
https://i.imgur.com/PZd7Ijx.mp4
I followed that call, checked the blame history, other commits were in the range of 3-8 years, this one is fairly recent. With 0 knowledge of the code I am just taking the blame approach here, maybe this bit of work will help someone with more experience working on freecad pinpoint this faster.
https://github.com/FreeCAD/FreeCAD/comm ... 0bc9349590
EDIT:
Hmm, the issue exists in 0.17 as well.
https://github.com/FreeCAD/FreeCAD/releases/tag/0.17
EDIT2:
And in 0.16 as well.
https://github.com/FreeCAD/FreeCAD/releases/tag/0.16
There is no archive of older precompiled versions for linux (that I know of), I just have to assume at this point that this has been there since forever.
Re: Ticket #4272 - Pick radius flickering
Postby Kunda1 » Sun Feb 23, 2020 12:48 am
OP opened issue #4272
Mod Edit: Please x-post back to ticket in the thread next time.
Thanks for reporting.
