Refine does not remove edges
kisolre
Postby kisolre » Sat Feb 22, 2020 7:37 am
I was trying to mirror whole body inside itself by using scaled to -1 clone and fusing to original. It lookas like it works but then I tryed to refine the features and it did not remove internal edges. Any idea why?
OS: Windows 8.1 (6.3)
Version: 0.19.19678 (Git)
Hash: b34f0aef34297c5eda6fb5cf1bbc1b43d452a31d
Python version: 3.6.8
Qt version: 5.12.1
RefineErr.FCStd
(26.69 KiB) Downloaded 6 times
UR_
Re: Refine does not remove edges
Postby UR_ » Sat Feb 22, 2020 7:57 am
Different types of surfaces can't be "refined" together.
Screenshot 005.png (11.95 KiB) Viewed 143 times
Screenshot 006.png (15.88 KiB) Viewed 143 times
kisolre
Postby kisolre » Sat Feb 22, 2020 9:16 am
Why are they different? Did the clone convert that Plane to BSplineSurface? I tried just displacing the clone and it is properly refined. But any scale <>1 causes such conversion. Is it OCC thing and is there a way to avoid it?
How do you inspect the faces like in your scfreenshots?
UR_
Postby UR_ » Sat Feb 22, 2020 10:00 am
Done with "Info" tool from CurvesWB.
Screenshot 007.png (22.12 KiB) Viewed 119 times
openBrain
Postby openBrain » Sat Feb 22, 2020 10:33 am
I think so but don't know why. Link seems to not suffer this problem when scaled. ;)
Site Admin
Postby wmayer » Sat Feb 22, 2020 11:20 am
OCCT has two transformation methods: a geometric transformation and a transformation that changes the placement
For the geometric transformation OCCT has the habit to convert all geometries into B-Spline curves/surfaces. It does so even if the transformation is a simple translation.
For the latter OCCT doesn't touch the underlying geometry. But for scaling operations (especially when values are different in the local X,Y,Z axes) you must use the geometric variant.
