Draft Module No Longer Functions [solved]
ppemawm
Postby ppemawm » Thu Aug 08, 2013 2:19 pm
I somehow lost my Draft module and receive the following error if selecting from the toolbar:
local variable 'DraftTools' referenced before assignment
File "C:\Program Files (x86)\FreeCAD0.13\Mod\Draft\InitGui.py", line 197, in Initialize
self.appendToolbar(str(DraftTools.translate("draft","Draft creation tools")),self.cmdList)
The Draft drop down menu does not show and the toolbars are missing
I uninstalled and reinstalled FreeCad but still had the error. I also searched the forum and found reference to a similar situation but did not understand how to fix it:
viewtopic.php?f=3&t=3686&p=28801&hilit= ... ent#p28811
Can anyone please help?
OS: Windows 7
Platform: 32-bit
Version: 0.13.1828
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.3.0
"It is a poor workman who blames his tools..." ;)
NormandC
Re: Draft Module No Longer Functions
Postby NormandC » Thu Aug 08, 2013 2:33 pm
There's a folder that contains 2 configuration files: system.cfg and user.cfg. On Linux the folder is named .FreeCAD (the dot at the front makes it a hidden folder).
In another "FreeCAD" folder, there's a "FreeCAD.conf" file.
On Windows I have no idea where they are located. If you can locate them, delete them - FreeCAD will recreate those files with the default settings the next time it launches. This will remove your own settings.
That's what I did to fix the problem you have.
If you do find these files, please tell us where they are located on Windows 7. Then I will know for the next time someone needs it.
oldestfox
Postby oldestfox » Thu Aug 08, 2013 3:17 pm
normandc wrote: If you do find these files, please tell us where they are located on Windows 7
I don't know about Win7, but in WinXP they are located here:
C:\Documents and Settings\Administrator\Application Data\FreeCAD
Of course the Drive and User will change. And I don't know if MS has renamed the folders for the same use or not. Probably so. :o
ppemawm
Re: Draft Module No Longer Functions--[solved]
Postby ppemawm » Thu Aug 08, 2013 4:03 pm
Thanks guys.
I found the files using Windows Search using "Freecad", deleted them, and, voila, the Draft Workbench is back, and it functions!
Of course, I lost all of my preferences and custom toolbars, but a small price to pay for getting back to work.
In Windows 7:
.Freecad file was in C:/Users/.../AppData/Local/Freecad/Freecad
sys.cfg and user.cfg are in C:/Users/.../AppData/Roaming/Freecad
where /.../ is whatever you have named your computer
Who says we greybeards can't learn something new.
Now, if I can just remember it for next time...
