Zoom to physical size
M4x
Re: Zoom to physical size
Post by M4x »
Creating a drawing with TechDraw could be useful too.
koirat
Post by koirat »
Script works, thank you.
TheMarkster
Post by TheMarkster »
https://github.com/FreeCAD/FreeCAD/pull/5125
This PR adds Mario's kisolre's macro to the View menu:
Snip macro screenshot-e4c5c2.png (93.96 KiB) Viewed 1347 times
If someone wants to build it and test it that would be nice. It doesn't work properly on my build machine, which is running inside a virtual machine, but neither does the macro and it works on my host machine.
mario52
Post by mario52 »
Hi
good addition tanks but :
TheMarkster wrote: Sat Oct 23, 2021 11:41 pm This PR adds Mario's macro to the View menu:
this is not Mario's macro this is very good kisolre's macro ([FEATURE REQUEST] Life-size view ?)
there is with FreeCAD the scale view (by carlopav)
carlopav wrote:ping
but give the error and not run
13:40:57 Traceback (most recent call last):
13:40:57 File "C:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\Mod\Draft\draftutils\init_draft_statusbar.py", line 171, in _set_scale
13:40:57 scale_widget.scaleLabel.setText(text_scale)
13:40:57 AttributeError: 'NoneType' object has no attribute 'scaleLabel'
OS: Windows 10 (10.0)
Version: 0.20.25943 (Git)
Hash: a65464b722a846bd2999aa2fecdff1132b15b297
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.2
Locale: French/Mars (fr_MA)
mario
Roy_043
Post by Roy_043 »
mario52 wrote: Sun Oct 24, 2021 11:58 am FreeCAD the scale view
This widget has nothing to do with scaling the view. See Draft_annotation_scale_widget.
I have no issue with the widget. But we would probably need a step-by-step scenario to verify.
Version: 0.20.26155 (Git)
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
mario52
Post by mario52 »
Hi
ok but not work (tested by Draft_Text)
20:05:56 Traceback (most recent call last):
20:05:56 File "C:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\Mod\Draft\draftutils\init_draft_statusbar.py", line 171, in _set_scale
20:05:56 scale_widget.scaleLabel.setText(text_scale)
20:05:56 AttributeError: 'NoneType' object has no attribute 'scaleLabel'
TheMarkster wrote:ping
Based on a macro from mario52:
if you want to correct the name (first post github) of the real author kisolre
thanks
mario
TheMarkster
mario52 wrote: Sun Oct 24, 2021 6:06 pm Hi
thanks
mario
I have corrected on github and in comments in the code to give proper credit to kisolre.
carlopav
Post by carlopav »
mario52 wrote: Sun Oct 24, 2021 6:06 pm ok but not work (tested by Draft_Text)
Can you post the steps to reproduce? I also do not experience problems with the scale widget...
OS: Windows 10 Version 2009
Version: 0.20.26035 +4 (Git)
Branch: Draft_newSubelementMove
Hash: e26b6c04f887bacb5bceba5a1e9dfb4a87bd15a4
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Italian/Italy (it_IT)
mario52
Post by mario52 »
Hi
@carlopav only if the widget is in top toolBar
other : if the widget is below, i reduce FC after i restore FC the widget is positionned in top toolBar
Qt version: 5.12.9
OCC version: 7.5.2
mario
