Hello,
I have a couple of projects I've created to help manage my clutter & failing furniture. The plan is to use these designs to cut storage solutions out of plywood with a CNC router. I'll attach the repos below.
Adjustable Storage Dresser
Stackable Flat Box
My aim with both of these projects is to set them up so that dimensions can be changed via spreadsheet parameters & the rest of the piece parts scale & adjust placement accordingly, saving the user the time of configuring dovetail size & piece placement manually.
I've sat on these for a couple of months now without working on them. I'm hoping to complete them now that I have more time to focus on them. I'm looking for input on what I can be practicing better, and maybe thoughts on how realistic this is.
Any input is welcome. Thanks for looking.
Adjustable Storage Projects
Re: Adjustable Storage Projects
Just some thoughts.
Did you use the LC Interlocking workbench? It gives you folding. I nevery tried it with expressions.
Why not using an assembly workbench, e.g. Assembly3, Assembly4 or A2plus to allow the users to check out your parts in 3D and actually stack them?
I guess you are aware that you could access dimensions in a spreadsheet when it is in another file (https://wiki.freecadweb.org/Spreadsheet_Workbench)
Did think about using the Path WB to actually include G-Code generation for people with a router in your file?
Thank you for the recommendations catman. I will look further into those workbenches (for those watching, none of the aforementioned are default except for the Path WB--you will need to download them via Macro -> Macros ... -> Addons...).
As far as stetting up Path GCode, I think I will leave that for the end-user. Everyone's setup is different, so I'll leave the CAM stuff alone. For this project, I'm primarily focused on proper design.
