[SOLVED] importing SVG: arc path is not being imported
kingkro123
Postby kingkro123 » Tue Mar 03, 2020 1:58 pm
Dear Forum,
I have an SVG of 4 objects.
When importing into freecad one of the objects is not shown (path3065). It happens to be an arc shape.
I've searched the forum and web and can't find a solution
I have attached the SVG and FCStd, as well as a screenshot.
thanks in advance for your assistance
Annotation 2020-03-03 135634.png (106.84 KiB) Viewed 335 times
Regards,
Richard
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
coral6a_plain.svg
(2.73 KiB) Downloaded 7 times
coral6a_plain.FCStd
(4.63 KiB) Downloaded 4 times
Re: importing SVG: arc path is not being imported
Postby chrisb » Tue Mar 03, 2020 6:07 pm
Hi and welcome to the forum!
Interesting issue. I have tried with a recent 0.19 and get the same result when importing as geometry. However, if I import as drawing all 4 are present. This means to me that FreeCAD can recognize all four subpaths.
Postby chrisb » Tue Mar 03, 2020 6:10 pm
The problem seems to be that FreeCAD cannot handle an inkscape path with just one point. If you add another point (in inkscape by double clicking somewhere on the path) it is imported correctly into FreeCAD.
kingkro123
Postby kingkro123 » Wed Mar 04, 2020 12:36 pm
Many thanks Chris.
I've taken your advice and executed 'Convert selected object's stroke to path' which added in the nodes needed for freecad to read in the geometry.
Seems an obvious step now that I know :)
Kind regards,
Richard
Re: [SOLVED] importing SVG: arc path is not being imported
Postby Kunda1 » Wed Mar 04, 2020 4:35 pm
Where should this be documented if it isn't yet?
openBrain
Postby openBrain » Wed Mar 04, 2020 5:22 pm
Good to document but better to fix IMO. ;)
Roy_043
Postby Roy_043 » Fri Mar 06, 2020 5:50 pm
I have added this as a limitation on this page:
https://wiki.freecadweb.org/Draft_SVG
Postby Kunda1 » Fri Mar 06, 2020 5:57 pm
Thank you very much
openBrain
Postby openBrain » Sun Mar 08, 2020 2:41 pm
Here is the culprit => https://github.com/FreeCAD/FreeCAD/blob ... G.py#L1105
It checks that ending point is different from starting point. Which of course can make sense for cubic Bezier curves.
I disabled the check and everything runs fine.
Same problem may happen with quadratic Bezier curve.
Also I find this condition is checked for lines (which is OK), tested with different coding for vertical lines and not tested at all for horizontal lines.
yorik wrote: Ping
May you remember why these checks were added and if they can be safely removed ?
