How to Make Toolbars Stay Where I Put Them?
bejant
Postby bejant » Wed Aug 14, 2013 1:51 am
When I start FreeCAD and switch to the Part Design workbench, the Sketcher Constraint toolbar is not fully visible so I move it (sometimes I move the Sketcher Geometry toolbar too) to make the whole toolbar visible. When I close FreeCAD and start it later, the toolbars are back where they originally were instead of where I moved them. So, how can I get them to stay put instead of having to move them every time I go into FreeCAD? It's probably something simple that I'm missing here...
Toolbars in their original places every time I start FreeCAD:
Toolbars after I move them and where I would like them to stay:
OS: Windows XP
Platform: 32-bit
Version: 0.14.2192 (Git)
Hash: b63f9d7a2b440e1363508976ec105dac31d7f698
Python version: 2.6.2
Qt version: 4.5.2
Coin version: 3.1.0
SoQt version: 1.4.1
OCC version: 6.5.1
Site Admin
Re: How to Make Toolbars Stay Where I Put Them?
Postby wmayer » Wed Aug 14, 2013 8:23 am
When closing FreeCAD we store the current layout (the positions of tool bars and dock windows) to the registry. With the next start we read in these settings from the registry and try to restore the layout. However, if your startup workbench is neither the Sketcher nor Part design workbench this doesn't work because restoring the layout of a non-existent tool bar is not possible.
So, you have to make one the workbenches your default one.
bejant
Postby bejant » Wed Aug 14, 2013 2:36 pm
Thanks!
triplus
Postby triplus » Wed Aug 14, 2013 4:45 pm
Yes, currently you can only customize position of toolbars from default workbench (workbench you selected to start by default in preferences). All other workbenches won't save that custom layout and it will be lost after FreeCAD restarts.
I thought it was "Linux" related but now i see it's "cross-platform" feature. ;)
nahshon
Postby nahshon » Thu Aug 15, 2013 1:49 am
I think each workbench should be responsible for placing its toolbars when activated.
Possibly related issue. Settings for a workbench are not present in the settings dialog until the first time that workbench was activated.
Site Admin
Postby wmayer » Thu Aug 15, 2013 7:51 am
A couple of years ago we had implemented this but it led to a lot of problems. Over time the data written to the registry get corrupted and Qt created some strange phantom widgets when reading back these data and also totally misplaced the tool bars. And also the memory consumption went up noticeably. That's why we limited it to restore the layout only at startup.
oldestfox
Postby oldestfox » Thu Aug 15, 2013 3:55 pm
wmayer wrote:Over time the data written to the registry
Is this the MS Windows OS registry?
Site Admin
Postby wmayer » Fri Aug 16, 2013 8:13 am
Yes, it's handled by the Qt class QSettings.
derei
Postby derei » Sat Apr 09, 2016 5:44 pm
Why don't you use some .ini files where to store the position and order for the toolbars?
Each workbench should have its own .ini file that is read at the moment where a workbench is selected. This way, the startup workbench would arrange itself on load and other workbenches would also arrange themselves whenever one of them is selected from the list.
I know it sounds easy talking and the reality is most of the time different, but storing settings in a file that gets rewritten if one wants to save the toolbars (you just can add a Save Workspace Layout menu entry), will avoid getting registry messed-up.
triplus
Postby triplus » Sat Apr 09, 2016 6:29 pm
I did some experiments with this in the past (TabBar) and store/restore issue probably could be resolved. But after that there are other issues involved and all sorts of unwanted side effects start to prevent good end user experience.
Therefore for whoever tackles this it will represent a challenge. But then again if it wouldn't represent a challenge it would probably be resolved by now. ;)
