[Fixed][Bug#4285] Bevel/Chamfer invert surface normal
fc_tofu
Re: [Bug#4285] 0.19pre PartWB, Bevel/Chamfer command invert surface normal
Post by fc_tofu »
wandererfan wrote: Fri Jun 05, 2020 1:34 pm Let me know if you have any problems.
With the face number of benchmark cube as reference, I made a table of faces orientation.
It seems face orientation doesnot matter in valid solid.
Later I will look into edge orientation.
Thank you.
wandererfan
Post by wandererfan »
fc_tofu wrote: Fri Jun 05, 2020 3:27 pm It seems face orientation doesnot matter in valid solid.
Not directly, no. Face orientation indicates whether the Face's normal points the same way as the underlying surface's normal or not. https://opencascade.blogspot.com/2009/02/continued.html
The first thing to check would be if all the face normals are pointing "out". That is the most correct configuration. All pointing in works for some things and not others. Some in and some out usually causes problems.
fc_tofu
Post by fc_tofu »
wandererfan wrote: Fri Jun 05, 2020 6:39 pm The first thing to check would be if all the face normals are pointing "out".
The check results prove that all cubes face normal are pointing outside, in the above test.
I made a new test. I created cube "10_3DOffset" (3D Offest with positive value, 10mm*10mm*10mm) first, then made 3 derivations from "10_3DOffset" .
21_Rebuild: Downgrade to faces then Upgrade to solid
22_SimpleCopy: PartWB >Simple Copy
23_Reimport: Export as STEP then reimport
3doffset_compare_before.FCStd
(11.35 KiB) Downloaded 39 times
Above: red-marked cube will cause flip normal error in chamfer operation, and the other two cubes get no error in chamfer.
Above: chamfer operation (5mm width) on sample cubes
New test shows that, all sample cubes have same faces/wires/edges orientations.
So at last, your check tool helped exclude orientations from suspicion. The culprit is hidding at lower level.
A new find is, reimporting as BREP reproduces the bug, whereas reimporting as STEP fixes the bug.
Summary for bug scenarios,
1. scenarios where bug happens
1.1 3D offset with postive value
1.2 simple copy of 1.1 (also, transformed copy/element copy)
1.3 reimport 1.1 as BREP format
2. scenarios where no bug happens
2.1 3D offset with negative value
2.2 rebuild 1.1 with Downgrade and Upgrade
2.3 reimport 1.1 as STEP format
2.4 refine 1.1
I extracted .brp from .FCStd file, for other people could debug more easily.
ps.
OCCT BREP format official doc:
https://dev.opencascade.org/doc/overvie ... ep_wp.html
2.1_negative_valid.brp
(8.35 KiB) Downloaded 43 times
1.1_positive_error.brp
(8.7 KiB) Downloaded 45 times
fc_tofu
Re: [Bug#4285] Bevel/Chamfer invert surface normal
Post by fc_tofu »
For now, I find a better (than rebuild/reimport) workaround for normal users, "PartWB >Refine shape" on defect solid before Bevel/Chamfer.
"Refine shape" is parametric operator, so it won't break existing parametric workflow.
(On the contrary, rebuild/reimport workaround break existing parametric workflow.)
In my tests, this workaround is valid for both 3D-Offset (positive) and Thickness (positive), for both Bevel and Chamfer.
For coders, I made sample models for comparison.
Befor refinement:
(8.7 KiB) Downloaded 37 times
After refinement:
2.4_positive_refined_valid.brp
(8.91 KiB) Downloaded 45 times
I still donnot know, wether the culprit is at 3D Offset/Thickness or at Bevel/Chamfer.
Possibly related sources:
https://github.com/FreeCAD/FreeCAD/blob ... Refine.cpp
https://github.com/FreeCAD/FreeCAD/blob ... setFix.cpp
https://github.com/FreeCAD/FreeCAD/blob ... Offset.cpp
https://github.com/FreeCAD/FreeCAD/blob ... atures.cpp
3doffset_compare_refine.FCStd
(22.58 KiB) Downloaded 56 times
fc_tofu
Post by fc_tofu »
PartWB Chamfer
https://github.com/FreeCAD/FreeCAD/blob ... hamfer.cpp
PartDesign Chamfer
On same defect solid, PartWB Chamfer make invalid result, while PD Chamfer make valid result.
Who can tell the reason from their code?
ulrich1a
Post by ulrich1a »
I got a negative volume for those invalid parts.
>>> App.ActiveDocument.Fillet.Shape.Volume
-499.5250740130765
Ulrich
fc_tofu
Post by fc_tofu »
ulrich1a wrote: Sat Jun 06, 2020 7:33 pm I got a negative volume for those invalid parts.
Thank you, also Analyze tool find error in invalid Bevel/Chamfer,
I'm curious what's wrong on Offset/Thickness shapes before Bevel/Chamfer.
wandererfan
Re: [Ticket#4285] 0.19pre PartWB, Bevel/Chamfer command invert surface normal
fc_tofu wrote: Mon May 04, 2020 1:18 pm This is a severe bug, hope more coders pay attention to it. Thanks.
I've got it. Fix will be along shortly.
fc_tofu
Post by fc_tofu »
wandererfan wrote: Sun Jun 07, 2020 3:42 pm I've got it. Fix will be along shortly.
Congratulations!
I diffed .brp files between invalid offset and its refinement. The geometry part is almost same. The shape part change a lot, I have no clue yet.
I have a concept. If the culprit can hardly be located, refine function could be appended to Offset/Thickness code as workaround.
wandererfan
should be fixed by git commit 73f086f73d.
