convert iv file to dae file which is always empty
albertfq
Post by albertfq »
Hi all,
I'm new to FreeCAD and meshes and I'm trying to convert iv files to dae files. With import option, I can import and visualize the models very well. After I export the file with 'dae' format, the file is 1kb and when I import again the generated dae file, it's nothing in the FreeCAD. I also tried to export other format such as 'obj', it's empty too.
Basic Info:
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Btw I saw some blog that it might be issue with python 3.6.6, how can we install FreeCAD with python 2.7? If this is the case.
sgrogan
Re: convert iv file to dae file which is always empty
Post by sgrogan »
albertfq wrote: Thu Mar 05, 2020 11:11 pm I also tried to export other format such as 'obj', it's empty too.
I can create a Part Cube and a Mesh cube and export to .dae and Open in another file.
Can you post a sample iv that has this behavior?
Qt version: 5.6.2
My exported .dae file
coltt.dae
(7.03 KiB) Downloaded 33 times
"fight the good fight"
albertfq
Post by albertfq »
Thks a lot. Here in the attachment is the .iv file that I had trouble with.
Founder
Post by wmayer »
albertfq wrote: Fri Mar 06, 2020 7:36 pm Thks a lot. Here in the attachment is the .iv file that I had trouble with.
The .iv file format is used by OpenInventor (Coin3d) to store the scene graph of the visual representation of the actual data model. Now if you load the .iv file then you just get the visual representation but you don't automatically get the data model, i.e. the mesh object in your case.
You should give MeshLab a chance because this supports quite a lot of mesh formats including the .iv format.
albertfq
Post by albertfq »
wmayer wrote: Sat Mar 07, 2020 5:02 pm
Thanks for the tip. I tried meshlab but unfortunately it also cannot import .iv files.
Founder
Post by wmayer »
If you are still interested I have found a way to convert the .iv file into an STL file. This STL can be loaded and converted into an other mesh format.
Founder
Post by wmayer »
Since git commit 601ac707b207c6 it's possible to do:
import MeshGui
MeshGui.convertToSTL("input_file.iv", "output_file.stl")
Reload the STL and save it into another format.
