What am I doing wrong?
By the way, if you use openscad (appimage 0.19) in the layout, you get an error -
File "/tmp/.mount_FreeCA0EDdBk/usr/Mod/OpenSCAD/OpenSCADUtils.py", line 457, in meshoptempfile
result = callopenscadmeshstring('%s(){%s}' % (opname,meshimports))
File "/tmp/.mount_FreeCA0EDdBk/usr/Mod/OpenSCAD/OpenSCADUtils.py", line 421, in callopenscadmeshstring
tmpfilename=callopenscadstring(scadstr,'stl')
File "/tmp/.mount_FreeCA0EDdBk/usr/Mod/OpenSCAD/OpenSCADUtils.py", line 198, in callopenscadstring
outputfilename = callopenscad(inputfilename,outputext=outputext,\
File "/tmp/.mount_FreeCA0EDdBk/usr/Mod/OpenSCAD/OpenSCADUtils.py", line 183, in callopenscad
check_output2([osfilename,'-o',outputfilename, inputfilename])
File "/tmp/.mount_FreeCA0EDdBk/usr/Mod/OpenSCAD/OpenSCADUtils.py", line 163, in check_output2
raise OpenSCADError('%s %s\n' % (stdoutd.strip(),stderrd.strip()))
<class 'OpenSCADUtils.OpenSCADError'>: " /usr/bin/openscad: /tmp/.mount_FreeCA0EDdBk/usr/lib/libQt5Core.so.5: version `Qt_5.14' not found (required by /usr/bin/openscad)\n/usr/bin/openscad: /tmp/.mount_FreeCA0EDdBk/usr/lib/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libqscintilla2_qt5.so.15)\n"
1096.62 <App> Document.cpp(3715): Failed to recompute test#_______________________________2020_03_11_00_36_35_Mesh: " /usr/bin/openscad: /tmp/.mount_FreeCA0EDdBk/usr/lib/libQt5Core.so.5: version `Qt_5.14' not found (required by /usr/bin/openscad)\n/usr/bin/openscad: /tmp/.mount_FreeCA0EDdBk/usr/lib/libQt5Core.so.5: version `Qt_5.13' not found (required by /usr/lib/libqscintilla2_qt5.so.15)\n"
Recompute failed! Please check report view.
Version: 0.19.19955 (Git) AppImage
Hash: fd907d6d9789f71007b8d0177d167f1de82629b8
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Russian/Russia (ru_RU)
