Why is this sketch not closed
Re: Why is this sketch not closed
Postby chrisb » Tue Mar 17, 2020 8:41 am
Forthman wrote:
Tue Mar 17, 2020 8:21 am
The sketch seems to be attached on something
if i set "Map Mode" to "desactivated" it's ok :idea:
I guess this recomputes the sketch as well, so that may be the reason for the fix.
openBrain
Postby openBrain » Tue Mar 17, 2020 9:41 am
chrisb wrote:
Tue Mar 17, 2020 12:08 am
DogLeg recomputes here without leavong open vertices, Levenberg-Marquardt leaves it open at some tangents. I remember topics talking about this. LM solver should be used with great care.
I definitely mistook here and LM solver definitely is the reason. Thanks for overwatching @chrisb. ;)
Postby chrisb » Tue Mar 17, 2020 10:53 am
The sketch is rather simple, so without a faint memory of the issues I wouldn't have guessed that it could be the solver.
insomniux
Postby insomniux » Tue Mar 17, 2020 7:49 pm
Thanks to all who responded. All are right. Sometimes only recalculating helps, removing the attachment of the sketch helps, etc. I've done some comparison between FC versions and the different solvers. I can confirm chrisb's analysis. When I use DogLeg the sketch is valid and makes a valid pad, when I use LM the curve is not closing well and yields an invalid sketch for padding. I've confirmed this by switching several times between the two solver algorithms.
Thanks again for your input!
Mike
Postby chrisb » Fri Mar 20, 2020 1:25 pm
Here is a simplified version of the sketch. It can be padded after solving with DogLeg, and cannot be padded after solving with Levenberg-Marquardt. I will add this to issue #3658.
Snip macro screenshot-0bd2ed.png (5.13 KiB) Viewed 50 times
LMvsDogLeg.FCStd
(5.89 KiB) Downloaded 4 times
