Part Primitives, Create Tube has no Map-Mode
in Freecad 0.19 you can find a new primitives called tube under Part, Primitives, Create tube.
It has no Map-Mode.
Why?
Please improve this tool with a map mode.
Best regards
Wilfried
It has no Map-Mode.
Why?
Best regards
Wilfried
- papyblaise
Re: Part Primitives, Create Tube has no Map-Mode
I have the 20052 version but Idon't see this new function
Exists in 20036
- CreateTube.jpg (66.17 KiB) Viewed 1549 times
https://github.com/FreeCAD/FreeCAD/comm ... /Shapes.pypapyblaise wrote: ↑Thu Mar 19, 2020 12:19 pm I have the 20052 version but Idon't see this new function
This Tube object seems like it was created in January 2019, so well over a year.
It's a pretty simple object, it just creates a basic Part_Feature, and adds the three properties Height, Inner Radius, Outer Radius, and that's it.
It is a scripted object made in Python, but it's not a complex object at all. It is not one of the Part_Primitives, so it lacks the attachment behavior those objects have.
class TubeFeature:
def __init__(self, obj):
obj.Proxy = self
obj.addProperty("App::PropertyLength","OuterRadius","Tube","Outer radius").OuterRadius = 5.0
obj.addProperty("App::PropertyLength","InnerRadius","Tube","Inner radius").InnerRadius = 2.0
obj.addProperty("App::PropertyLength","Height","Tube", "Height of the tube").Height = 10.0
def execute(self, fp):
fp.Shape = makeTube(fp.OuterRadius, fp.InnerRadius, fp.Height)
- papyblaise
Sorry, I find it in Part Wb , it works well and simply to use
If some of this features that work in an explicit way are implemented in such a way that it is impossible to make them associative (fully parametric) or until they are changed to work in this way, I would suggest to make their icons in a special color (maybe pink?) or use the existing small overlay pink icon that we already have in PartDesign when features are not attached, so that it will be clear to the user that this features work differently and so increase awareness about this. To my knowledge PartWB Mirror and PartWB Projection are also explicit.
- Part_Tube_Explicit.svg
- (7.49 KiB) Downloaded 48 times
- Part_Tube_Explicit.jpg (8.03 KiB) Viewed 1459 times
As a workaround if you need to be able to attach it you can create a draft clone, hide the original tube, and attach the clone.freecad-heini-1 wrote: ↑Thu Mar 19, 2020 8:55 am Hi,
It has no Map-Mode.
Why?
Best regards
Wilfried
I'm really happy that this feature exists - I've been arguing for it for years.
But in my version it does not work, a "tube" symbol occurs in the tree, but it's invisible and grayed out and cannot be activated.
Console output:
My version:
Cheers,
Wolf
Console output:
connect failed: Datei oder Verzeichnis nicht gefunden
Running the Python command 'Part_Tube' failed:
File "/usr/share/freecad-daily/Mod/Part/BasicShapes/CommandShapes.py", line 54, in Activated
Shapes.TubeFeature(tube)
File "/usr/share/freecad-daily/Mod/Part/BasicShapes/Shapes.py", line 46, in __init__
obj.addExtension("Part::AttachExtensionPython")
function takes exactly 2 arguments (1 given)
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: dbaa2c1ba458d34244420037d4ff91b3841411ce
Python version: 3.8.5
Qt version: 5.12.8
Wolf
Work fine in my version...
OS: Ubuntu 20.04.2 LTS (XFCE/ubuntustudio)
Version: 0.20.25111 (Git)
Hash: bc9beffc45bcd0e1980b3502b43a3a35a96b5406
Qt version: 5.12.8
OCC version: 7.5.1
Qt version: 5.12.8
OCC version: 7.5.1
