FreeCADGui.ActiveDocument.ActiveView.getViewDirection()
This output a dxf fileIf you select object in tree view and run standalone macro or just copy/paste in Python console does it work:
import os
homepath = os.path.expanduser("~")
selection = FreeCADGui.Selection.getSelection()
obj = selection[0]
filename = homepath + os.sep + obj.Name + ".dxf"
import importDXF
importDXF.export(selection,filename)
It return:I could be wrong but it looks like importDXF.py is not getting what it wants. If you copy/paste this in Python console when at least one document is opened:
Vector (0.0, 0.0, -1.0)
import os
obj = selection[0]
filename = homepath + os.sep + obj.Label.encode("utf-8") + ".dxf"
import importDXF
YesDoes this work too:
No, the macro never completes, seem to stop on the last line.P.S. What about selecting object in tree view and copy/paste the macro in the Python console.
Interesting then i guess the whole macro should work too. Do you have the macro saved in a macro folder set in FreeCAD preferences?Yes
Yes just press enter at the last line and it will complete.No, the macro never completes, seem to stop on the last line.
Macro path is set like thisInteresting then i guess the whole macro should work too. Do you have the macro saved in a macro folder set in FreeCAD preferences?
And the macro filenameEdit
..Prefrerences
....General
......Macro
........Macro path
/home/isak/Dokument/9_Projekt/cad/FeeCAD/Macro
/home/isak/Dokument/9_Projekt/cad/FeeCAD/Macro/ExoprtDxfSvg.FCMacro
No, nothing happens, but if I type a character and then press [ENTER] then it will throw me out with an error. I guess there are proper ways to quit, but I have not been searching.Yes just press enter at the last line and it will complete.
A small part of the code File "/usr/Mod/Draft/importDXF.py", line 1449 (The line markt "LINE1449)Traceback (most recent call last):
File "/home/isak/Dokument/9_Projekt/cad/FeeCAD/Macro/ExoprtDxfSvg.FCMacro", line 303, in <module>
File "/usr/Mod/Draft/importDXF.py", line 1449, in export
direction = FreeCADGui.ActiveDocument.ActiveView.getViewDirection()
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'getViewDirection'
def export(objectslist,filename,nospline=False):
"called when freecad exports a file. If nospline=True, bsplines are exported as straight segs"
global exportList
exportList = objectslist
if (len(exportList) == 1) and (Draft.getType(exportList[0]) == "ArchSectionView"):
# arch view: export it "as is"
dxf = exportList[0].Proxy.getDXF()
if dxf:
f = open(filename,"w")
f.write(dxf)
f.close()
elif (len(exportList) == 1) and (exportList[0].isDerivedFrom("Drawing::FeaturePage")):
# page: special hack-export! (see below)
exportPage(exportList[0],filename)
else:
# other cases, treat edges
dxf = dxfLibrary.Drawing()
for ob in exportList:
print "processing ",ob.Name
if ob.isDerivedFrom("Part::Feature"):
if FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft").GetBool("dxfmesh"):
sh = None
if not ob.Shape.isNull():
writeMesh(ob,dxf)
elif FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft").GetBool("dxfproject"):
LINE1449 direction = FreeCADGui.ActiveDocument.ActiveView.getViewDirection() LINE1449
sh = projectShape(ob.Shape,direction)
else:
if ob.Shape.Volume > 0:
sh = projectShape(ob.Shape,Vector(0,0,1))
else:
sh = ob.Shape
if sh:
if not sh.isNull():
if sh.ShapeType == 'Compound':
if (len(sh.Wires) == 1):
# only one wire in this compound, no lone edge -> polyline
if (len(sh.Wires[0].Edges) == len(sh.Edges)):
writeShape(sh,ob,dxf,nospline)
else:
# 1 wire + lone edges -> block
block = getBlock(sh,ob)
dxf.blocks.append(block)
dxf.append(dxfLibrary.Insert(name=ob.Name.upper()))
else:
# all other cases: block
else:
elif Draft.getType(ob) == "Annotation":
# texts
# temporary - as dxfLibrary doesn't support mtexts well, we use several single-line texts
# well, anyway, at the moment, Draft only writes single-line texts, so...
for text in ob.LabelText:
point = DraftVecUtils.tup(FreeCAD.Vector(ob.Position.x,
ob.Position.y-ob.LabelText.index(text),
ob.Position.z))
if gui: height = float(ob.ViewObject.FontSize)
else: height = 1
dxf.append(dxfLibrary.Text(text,point,height=height,
color=getACI(ob,text=True),
style='STANDARD',
layer=getGroup(ob,exportList)))
elif Draft.getType(ob) == "Dimension":
p1 = DraftVecUtils.tup(ob.Start)
p2 = DraftVecUtils.tup(ob.End)
base = Part.Line(ob.Start,ob.End).toShape()
proj = DraftGeomUtils.findDistance(ob.Dimline,base)
if not proj:
pbase = DraftVecUtils.tup(ob.End)
else:
pbase = DraftVecUtils.tup(ob.End.add(DraftVecUtils.neg(proj)))
dxf.append(dxfLibrary.Dimension(pbase,p1,p2,color=getACI(ob),
dxf.saveas(filename)
FreeCAD.Console.PrintMessage("successfully exported "+filename+"\r\n")
exportsDXF = 0
# Export DXF.
if exportsDXF == 1:
import FreeCAD
import Part
import Drawing
import math
import os
#-------------------------------- User Settings -------------------------------
# Centerpoint (centerpoint of combined views).
centerX = 420 / 2
centerY = 235 / 2
# Additional horizontal/vertical space between views.
viewsSpace = 40
# Maximum width/height of combined views.
# Used for auto-scale mode 0 and 1.
viewsSize = 170
# Scale.
# 0 - Maximum scale
# 1 - Maximum standard scale (1000:1 to 1:1000)
# 2 - Manual scale
scaleType = 0
manualScale = 1 # scaleType must be set to value 2.
scaleIso = 1 # Isometric view (Scale*scaleIso).
# Projection type.
# 0 - First angle
# 1 - Third angle
projectionType = 0
# Show hidden lines.
# 0 - False
# 1 - True
linesViews = 1
linesIso = 1
# Annotation (drawing info) shown under views.
# 0 = False
# 1 = True
annotationEnable = 1
textSize = 4
# Template location.
templateSet = App.getResourceDir() + 'Mod/Drawing/Templates/A3_Landscape.svg'
# Export to home folder.
# 0 - False
# 1 - True
exportsSVG = 1
exportsDXF = 1
#---------------------------- End Of User Settings ----------------------------
# Select part.
Piece = Gui.Selection.getSelectionEx()[0]
obj = selection[0]
autoDrawing = App.activeDocument().addObject('Drawing::FeaturePage', 'Drawing')
autoDrawing.Template = templateSet
# Part centerpoints.
XM = Piece.Object.Shape.BoundBox.XMax
Xm = Piece.Object.Shape.BoundBox.XMin
XC = Xm + ((XM - Xm) / 2)
YM = Piece.Object.Shape.BoundBox.YMax
Ym = Piece.Object.Shape.BoundBox.YMin
YC = Ym + ((YM - Ym) / 2)
ZM = Piece.Object.Shape.BoundBox.ZMax
Zm = Piece.Object.Shape.BoundBox.ZMin
ZC = Zm + ((ZM - Zm) / 2)
# Scale.
SX = XM - Xm
SY = YM - Ym
SZ = ZM - Zm
scaleMax = ((viewsSize - viewsSpace) / 2) / max(SZ, SY, SX)
if scaleType == 0:
scale = scaleMax
ratio = scaleMax
elif scaleType == 1:
if scaleMax > 2000 or scaleMax < 0.001:
scale = scaleMax
ratio = scaleMax
elif scaleMax > 1000 and scaleMax <= 2000:
scale = 1000
ratio = '1000:1'
elif scaleMax > 500 and scaleMax <= 1000:
scale = 500
ratio = '500:1'
elif scaleMax > 200 and scaleMax <= 500:
scale = 200
ratio = '200:1'
elif scaleMax > 100 and scaleMax <= 200:
scale = 100
ratio = '100:1'
elif scaleMax > 50 and scaleMax <= 100:
scale = 50
ratio = '50:1'
elif scaleMax > 20 and scaleMax <= 50:
scale = 20
ratio = '20:1'
elif scaleMax > 10 and scaleMax <= 20:
scale = 10
ratio = '10:1'
elif scaleMax > 5 and scaleMax <= 10:
scale = 5
ratio = '5:1'
elif scaleMax > 2 and scaleMax <= 5:
scale = 2
ratio = '2:1'
elif scaleMax > 1 and scaleMax <= 2:
scale = 1
ratio = '1:1'
elif scaleMax > 0.5 and scaleMax <= 1:
scale = 0.5
ratio = '1:2'
elif scaleMax > 0.2 and scaleMax <= 0.5:
scale = 0.2
ratio = '1:5'
elif scaleMax > 0.1 and scaleMax <= 0.2:
scale = 0.1
ratio = '1:10'
elif scaleMax > 0.05 and scaleMax <= 0.1:
scale = 0.05
ratio = '1:20'
elif scaleMax > 0.02 and scaleMax <= 0.05:
scale = 0.02
ratio = '1:50'
elif scaleMax > 0.01 and scaleMax <= 0.02:
scale = 0.01
ratio = '1:100'
elif scaleMax > 0.005 and scaleMax <= 0.01:
scale = 0.005
ratio = '1:200'
elif scaleMax > 0.002 and scaleMax <= 0.005:
scale = 0.002
ratio = '1:500'
elif scaleMax > 0.001 and scaleMax <= 0.002:
scale = 0.001
ratio = '1:1000'
elif scaleType == 2:
scale = manualScale
ratio = manualScale
# Views centerpoints.
X1 = centerX - viewsSpace / 2 - max(SZ, SY, SX) * scale / 2
Y1 = centerY - viewsSpace / 2 - max(SZ, SY, SX) * scale / 2
X2 = centerX + viewsSpace / 2 + max(SZ, SY, SX) * scale / 2
Y2 = centerY - viewsSpace / 2 - max(SZ, SY, SX) * scale / 2
X3 = centerX - viewsSpace / 2 - max(SZ, SY, SX) * scale / 2
Y3 = centerY + viewsSpace / 2 + max(SZ, SY, SX) * scale / 2
X4 = centerX + viewsSpace / 2 + max(SZ, SY, SX) * scale / 2
Y4 = centerY + viewsSpace / 2 + max(SZ, SY, SX) * scale / 2
# Front view.
viewFront = App.activeDocument().addObject('Drawing::FeatureViewPart', 'Front')
viewFront.Source = Piece.Object
if projectionType == 0:
angleFront = 270
viewFront.Direction = (0, 1, 0)
viewFront.Rotation = angleFront
viewFront.X = X1 - XC * scale
viewFront.Y = Y1 + ZC * scale
elif projectionType == 1:
angleFront = 270
viewFront.X = X3 - XC * scale
viewFront.Y = Y3 + ZC * scale
if linesViews == 0:
viewFront.ShowHiddenLines = False
elif linesViews == 1:
viewFront.ShowHiddenLines = True
viewFront.Scale = scale
autoDrawing.addObject(viewFront)
# Side view.
viewSide = App.activeDocument().addObject('Drawing::FeatureViewPart', 'Side')
viewSide.Source = Piece.Object
angleSide = 90
viewSide.Direction = (-1, 0, 0)
viewSide.Rotation = angleSide
viewSide.X = X2 - YC * scale
viewSide.Y = Y2 + ZC * scale
angleSide = 270
viewSide.Direction = (1, 0, 0)
viewSide.X = X4 + YC * scale
viewSide.Y = Y4 + ZC * scale
if linesViews == 0:
viewSide.ShowHiddenLines = False
viewSide.ShowHiddenLines = True
viewSide.Scale = scale
autoDrawing.addObject(viewSide)
# Top view.
viewTop = App.activeDocument().addObject('Drawing::FeatureViewPart', 'Top')
viewTop.Source = Piece.Object
angleTop = 0
viewTop.Direction = (0, 0, 1)
viewTop.Rotation = angleTop
viewTop.X = X3 - XC * scale
viewTop.Y = Y3 - YC * scale
angleTop = 0
viewTop.X = X1 - XC * scale
viewTop.Y = Y1 - YC * scale
if linesViews == 0:
viewTop.ShowHiddenLines = False
viewTop.ShowHiddenLines = True
viewTop.Scale = scale
autoDrawing.addObject(viewTop)
# Iso view.
viewIso = App.activeDocument().addObject('Drawing::FeatureViewPart', 'Isometric')
viewIso.Source = Piece.Object
angleIso = 60
viewIso.Direction = (1, 1, 1)
viewIso.Rotation = angleIso
k = math.sin(math.radians(45)) / math.sin(math.radians(60))
if XC >= YC:
viewIso.X = X4 - math.sqrt(2 * (YC - XC) ** 2) / 2 * scale * scaleIso
elif XC < YC:
viewIso.X = X4 + math.sqrt(2 * (YC - XC) ** 2) / 2 * scale * scaleIso
viewIso.Y = Y4 + ((max(XC, YC, ZC) - XC) * k / 2) * scale * scaleIso + ((max(XC, YC, ZC) - YC) * k / 2) * scale * scaleIso - ((max(XC, YC, ZC) - ZC) * k) * scale * scaleIso
if XC >= YC:
viewIso.X = X2 - math.sqrt(2 * (YC - XC) ** 2) / 2 * scale * scaleIso
elif XC < YC:
viewIso.X = X2 + math.sqrt(2 * (YC - XC) ** 2) / 2 * scale * scaleIso
viewIso.Y = Y2 + ((max(XC, YC, ZC) - XC) * k / 2) * scale * scaleIso + ((max(XC, YC, ZC) - YC) * k / 2) * scale * scaleIso - ((max(XC, YC, ZC) - ZC) * k) * scale * scaleIso
if linesIso == 0:
viewIso.ShowHiddenLines = False
elif linesIso == 1:
viewIso.ShowHiddenLines = True
viewIso.Scale = scale * scaleIso
autoDrawing.addObject(viewIso)
# Annotation projection.
projection = 'first-angle'
projection = 'third-angle'
# Annotation.
if annotationEnable == 1:
annotation = App.activeDocument().addObject('Drawing::FeatureViewAnnotation', 'Annotation')
annotation.X = centerX - viewsSize / 2
annotation.Y = centerY + viewsSize / 2 + textSize
annotation.Scale = textSize
if scaleType != 1:
if scaleIso != 1:
annotation.Text = [unicode('Scale: ' + "%.3f" % ratio + ' (Iso: Scale*' + str(scaleIso) + ') Projection: ' + str(projection), 'utf-8'), ]
elif scaleIso == 1:
annotation.Text = [unicode('Scale: ' + "%.3f" % ratio + ' Projection: ' + str(projection), 'utf-8'), ]
if scaleIso != 1:
annotation.Text = [unicode('Scale: ' + str(ratio) + ' (Iso: Scale*' + str(scaleIso) + ') ' + ' Projection: ' + str(projection), 'utf-8'), ]
elif scaleIso == 1:
annotation.Text = [unicode('Scale: ' + str(ratio) + ' Projection: ' + str(projection), 'utf-8'), ]
autoDrawing.addObject(annotation)
# Refresh.
App.activeDocument().recompute()
# Export SVG.
if exportsSVG == 1:
filename = homepath + os.sep + obj.Label.encode("utf-8") + ".svg"
PageFile = open(App.activeDocument().Drawing.PageResult,'r')
OutFile = open(filename,'w')
OutFile.write(PageFile.read())
del OutFile,PageFile
# Export DXF.
if exportsDXF == 1:
import importDXF
Guessing that something must be wrong in my installation, either Debian or FreeCAD.Traceback (most recent call last):
File "/home/isak/.FreeCAD/ExportDxfSvg.FCMacro", line 304, in <module>
