Turning PAD around its axis
kennethbiles
Postby kennethbiles » Thu Mar 26, 2020 3:33 pm
Again a total newbie question. I will try to use proper terminology, so this will get wierd and confusing. I searched the forum and found many references to this question, but the answers did not appear to work for me.
I am making a support out of metal tube. This will have supports when looking from the front in the front plan going at a 45 degree angle from the horizontal top to the vertical side. To represent this in FreeCAD I did the following sucessfully.
In Sketcher. I created a constrained 2D object that was the appropriate size and shape. Snip_05_01
I changed workbenches to Part and used the PAD option to create a 3D object of the correct size
I created a cube of the correct size, shape and location and used the "Cut from two objects" tool to remove the center of the PAD to create a hollow tube with a 90 end and a 45 end.
Used the Angle, Axis and Position Properties of the PAD to place the hollow tube in the correct location in relation to the other objects of the grill support. For organization I have each object contained in a Part Body.
My issue is after all that.
To make the pad I had to draw the 45 on the XY plain then PAD that up. When in position the 45 of the object is in the wrong orientation in relation to the other objects (Snip_05_02). I can attach my FreeCAD file if it will help, but did not want to start with that because I have no idea of the size of that file.
Any help on how to do this, if it is possible, will be appreaciated. I have seen references to an Assembly Workbench, but assume that is still in development.
Thank you,
Ken
freedman
Re: Turning PAD around its axis
Postby freedman » Thu Mar 26, 2020 4:14 pm
That's a long post, first thing you said is you changed workbenches. The item your working on coud be done in Partdesign and Partdesign only. IMO you need to stay in there and then we can work out how to do this. I also noticed the Start workbench in your pic, if you goto Edit-preferences-startup workbench, set it Part design.
Bance
Postby Bance » Thu Mar 26, 2020 4:18 pm
Select extrude in the tree view, scroll down to position in the data tab, click in the value column that contains numbers and a button with an ellipses on will appear. Press this to bring up the placement dialogue, select the apply incremental changes button, play around to your heart's content.
Postby chrisb » Thu Mar 26, 2020 4:28 pm
From what I see, I think you can turn the first sketch of the beam by 90° to turn it around.
kennethbiles
Postby kennethbiles » Thu Mar 26, 2020 4:34 pm
I will try all of these things and let you know of my success....and multiple failures.
We learn from failure and stop at success, right?
Thank you all.
Ken
drmacro
Postby drmacro » Thu Mar 26, 2020 5:00 pm
freedman wrote: Thu Mar 26, 2020 4:14 pm That's a long post, first thing you said is you changed workbenches. The item your working on coud be done in Partdesign and Partdesign only. IMO you need to stay in there and then we can work out how to do this. I also noticed the Start workbench in your pic, if you goto Edit-preferences-startup workbench, set it Part design.
I have been musing...and this is a good example.
It may exist already, but, would a wiki that we could send people to to discuss the the why/when/where etc. of using the Part Design and Part workbenches. Is there a noob friendly page that discusses this? Please link me if there is.
My beginners, written treatise: Learning FreeCAD
