Are you sure this is the correct font? Any idea where it is in the source? or is this the default QT5 font?
[SOLVED]Numbers display as weird symbols
Re: Numbers display as weird symbols
AFAIK, every widget is selecting it's own font
Please see property editor from QtDesigner with any .ui file from FreeCAD.
example:
example:
I don't have QtDesigner and I'd like to avoid downloading the trial version if I can.
I see that the .ui files are xml files, so I expect the font properties to be mentioned in plain text; I opened each of them in Notepad++ and I made a search on "font"; results are in attachment.
Don't hesitate to tell me if what I did doesn't make sense.
- Fonts.pdf
- (79.62 KiB) Downloaded 41 times
Yeah, actually doing so doesn't make much sense.
Qt as a mechanism to get default font from the system, then propagating it through the widgets => https://doc.qt.io/qt-5/qwidget.html#font-prop
You can try to enter something like this in the Python Console to look if it improve things :
from PySide import QtGui
QtGui.QApplication.setFont(QtGui.QFont("Arial",10))
>>> QtGui.QApplication.setFont(QtGui.QFont("Arial",10))openBrain wrote: ↑Wed Apr 01, 2020 1:25 pm You can try to enter something like this in the Python Console to look if it improve things :Code: Select all
NameError: name 'QtGui' is not defined
Nobody is perfect ... but it doesn't solve the bloody thing
No change in the weird numbers display, but I can see all texts change size (numbers included) if I change the second argument.
I also tried different fonts (MS Sans Serif, Tahoma) and I see indeed the font change in all texts, but the same issue with numbers remains.
Btw, I tried the 32-bit version of FreeCAD as well, just in case - no more success.
I since reverted to the 64 bit version (0.18)
@daboga, I can't see anywhere in the thread that you have referenced the setting in this procedure: https://java.com/en/download/help/locale.xml
(I'm sure this setting has come up in the past with regard to a strange Windows display problem).
This solved the issue -Thanks a lot! (I'd never have found it by myself)Syres wrote: ↑Wed Apr 01, 2020 2:52 pm @daboga, I can't see anywhere in the thread that you have referenced the setting in this procedure: https://java.com/en/download/help/locale.xml
Thanks also to all those who tried and helped !!!
Just for future reference - "Language for non-Unicode programs" is the desired setting. What was yours set to?
