Zoom factor of scroll wheel? Preference?
The scroll wheel zoom seems to use a bigger zoom factor (per click) than the Std_ViewZoomIn and Std_ViewZoomOut commands. Is there a preference for this?
Edit: spelling.
Edit: spelling.
Re: Zoom factor of scroll wheel? Preference?
It's preferences ...Display....Navigation tab ....Zoom Step (to the right of "zoom at cursor" tick box)
at least that is where it is in 0.19.
Jim
OS: Ubuntu 18.04.4 LTS (KDE/plasma)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
That setting has an effect on 'scroll wheel' zoom but also on the zoom commands. I am looking for a setting (if any) to change 'scroll wheel' zoom only. A single scroll wheel click seems equal to using a zoom command twice.
Edit: Added 'click'.
Might be OS setting that sends several events?
I can change the number of text lines that a single mouse wheel click will scroll. But that setting has no effect in FreeCAD.
Taking note of my very limited C++ knowledge I'm guessing you should be looking in https://github.com/FreeCAD/FreeCAD/blob ... d.cpp#L687 , there's an explanation that I believe is relevant https://doc.qt.io/qt-5/qwheelevent.html#angleDelta
IMHO this should be a personalised parameter rather than a blanket setting as it appears to be at present if I've interpreted the code correctly.
The zoom factor by wheel mouse is exactly twice the factor of Std_ViewZoomIn/Std_ViewZoomOut because the one and same event is handled twice.
This function is called only once
https://github.com/FreeCAD/FreeCAD/blob ... .cpp#L1002
but before letting a QObject handle an event its event filters are called: https://github.com/FreeCAD/FreeCAD/blob ... r.cpp#L150
and this function is called twice.
@wmayer: Thank you!
Possible Mac regression https://forum.freecadweb.org/viewtopic.php?f=4&t=44855
