I've been using FreeCad 0.18 since yesterday.
Now the following problem, so that I can continue working with the step file, which I create with FreeCAD, the angular curves must become really round.
Enclosed a picture
I'm hoping you can help me.
Grüßle
Andi
Import PCB from KiCad, Polygon instead of round
- FreeCAD_Forum.PNG (164.39 KiB) Viewed 590 times
Re: Import PCB from KiCad, Polygon instead of round
Without an actual file we can only guess if that is just a visual representation or it is imported that way. Also if this is 1mm or 1km radius...
In KiCAD it is perfectly round, I export it without detours directly into FreeCAD, but then it is displayed angular.
In a VRML file the curves look worse.
Since we work on a PCB we are in the range of mm .
I tried to upload the KiCad file, but this format is not supported.
- COPPER.step
- (97.82 KiB) Downloaded 13 times
What format specifically did you try to upload?
Perhaps we can add KiCad file format(s) to phpbb ?kkremitzki wrote:
The step file contains 3 straight edges for that round. Maybe you have some setting in KiCAD exporter to convert arcs to edges on export?
So how can I edit this step file in FreeCAD 0.18?
So delete the angular curves and insert a quarter circle.
I have no idea what you want to do with that track so can not give meaningful answer. Please give more info.
What is the need for this to be round rather than a line approximation in FreeCAD or step?
I'm curious about the use case?
