OS: macOS 10.15
Version: 0.18.16146 (Git)
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
I have been referring to some beginner CAD exercises to improve my skills, they show the shape and a limited number of dimensions for you to work out how to build.
However there are two lines in this particular image that I'm not sure how to draw as I don't know what tool to use or where to place restraints.
I'm sure it's an easy problem to solve but would appreciate if someone could advise me.
Thanks
Problem to solve (beginner level)
Re: Problem to solve (beginner level)
I'm afraid we can't see your image....
you have to add it as an attachment(below the text input window) or you can drag and drop it in.
Thanks, picture now attached.
At a guess I'd say they were radii with tangental constraints.
You could include your file to make it easier to help.
Steve
Steve
Sure, I've attached it below. I tried using the arc tool to create a curve and then setting an tangent restraint but didn't know what to do about the radius.
- Shape3.FCStd
- (13.51 KiB) Downloaded 6 times
Also something to bear in mind it could just have been a poorly drafted original sketch with missing measurements.
Please note that some guesswork remains: the radii of these arcs are not given.
I had considered that. I've been able to make the two arcs but can find no way to define the radii from the sketch. So I assume the original template just didn't give that dimension.
Thanks for the input. I'm new to this and just wanted to make sure there wasn't an element I was missing.
