Where are the SNAP tools in Sketch Workbench?
geolux
Postby geolux » Sat Apr 04, 2020 2:29 pm
Hi there,
I'm drawing a building in a sketch. The rooms are not regular and I need to set the measure of the edges, diagonal, and more.
Yes I use the constraints (great tool) but I suffer the lack of the SNAP tools.
Is ther a possibility to anable its?
Re: Where are the SNAP tools in Sketch Workbench?
Postby chrisb » Sat Apr 04, 2020 4:44 pm
No snapping in Sketcher, it's all done by constraints. Check Autoconstraints box to get something slightly similar.
geolux
Postby geolux » Sat Apr 04, 2020 5:11 pm
Thank's
TheMarkster
Postby TheMarkster » Sat Apr 04, 2020 6:24 pm
Snip macro screenshot-cbfa7a.png (152.66 KiB) Viewed 203 times
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
carlopav
Postby carlopav » Sat Apr 04, 2020 7:04 pm
Postby chrisb » Sun Apr 05, 2020 12:56 am
Indeed, I forgot the grid. It is not much used among Sketcher friends, because snapping to the grid does not really connect the elements. This leads to issues when such sketch is used for features such as Pad or Pocket.
TheMarkster
Postby TheMarkster » Sun Apr 05, 2020 1:14 am
8-)
Yes, the problem is the snapped edges do not remain in place if the element is moved or constrained on the other end.
geolux
Postby geolux » Sun Apr 05, 2020 9:00 am
I knew the Autoconstraints and I used it, but sometime the Autoconstraints did not respond
Use the attached FC file and try to autoconstraints the highlighted line
Progetto.FCStd
(33.46 KiB) Downloaded 2 times
geolux
Postby geolux » Sun Apr 05, 2020 9:13 am
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
Postby chrisb » Sun Apr 05, 2020 10:43 am
Autoconstraints on/off is a property of the sketch, although what is displayed in the panel at the left depends on the preferences (known bug). You have to toggle autoconstraints off and on again and they should work.
