Bug in Freecad 0.19 development cycle - desktop seen through grid
Hi, In the recent freecad development builds, my desktop shows through the grid. there is a transparency in the grid when grid is on, and the content on my desktop is seen through.
i am referring to freecad0.19 development build 20514 for mac os. have attached a screenshot showing the same.
i hope this is the right forum to post bugs.
- Screenshot 2020-04-14 at 8.14.29 AM.png (706.92 KiB) Viewed 1699 times
Re: Bug in Freecad 0.19 development cycle - desktop seen through grid
It is the right forum, but you should attach your full FreeCAD info as described in the IMPORTANT forum rules linked above.
OS: macOS High Sierra (10.13)
Version: 0.19.20514 (Git)
Hash: a05ffd499366ab12fa1b43f37db73f4f1e9c332d
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
I can confirm that behaviour. Any transparent object (even pre-selected objects or datum planes) let the desktop shine through:
The problem seems to be related to the Qt version. Some time ago I built FreeCAD by myself using Qt 5.13 and that FreeCAD did not show the effect. However, currently I'm not able to build FreeCAD again, because that Qt-pyside2-Python3.8 mixture in Homebrew is a totally mess.
BR tom
Qt version: 5.12.5
OCC version: 7.4.0
BR tom
Looks like one of the "MacOS poorly supports openGL" bugs.
I don't think conda is the culprit. We had seen this sometimes long time ago in 0.17, perhaps even in 0.16. It seems rather to be a combination of Qt and graphics card driver. Perhaps there was a change in the Qt version at the same time with the conda packaging.
I also think that it is Qt related. As I said in my own compiled version using Qt 5.13 the problem did not occur. Or it is related to the OpenGL version used during the conda build vs. the OpenGL libraries installed in OSX, i.e. it could be related to the OSX version. I'm still on High Sierra. Do you know, which OSX version the conda build machine is running on? Which OSX version are you using? Does your FreeCAD installation also suffer from the transparency problem?chrisb wrote: ↑Tue Apr 14, 2020 12:58 pmI don't think conda is the culprit. We had seen this sometimes long time ago in 0.17, perhaps even in 0.16. It seems rather to be a combination of Qt and graphics card driver. Perhaps there was a change in the Qt version at the same time with the conda packaging.
Yes (but not the real cause IMO). Qt version has an impact for sure. Apple so strongly want to push their own (probably proprietary) rendering solution that they declared openGL as being deprecated ( ). So the MacOS support for openGL very probably lack some efforts. Guys at Qt made a big effort in Qt5.12 (and probably continuing in Qt5.13) to have all this working fine (for example, Intel GPUs also had problems with the Qt5 openGL).
I played with the asm3 branch of FreeCAD and wondered why the transparency problem did not occur there. However, sometimes also the official FreeCAD version does not suffer from the problem. Now I found out why: If I open my project using the menu "File | Open ..." then I see the transparent problem. But if I open the same project using "File | Recent files" then all is fine. Further I noticed an extra error message on the console when opening the project using "File | Open ...":
At first it doesn't seem to be related to the transparency issue. But maybe this error message comes from an exception, which prevents the graphics initialisation being completed.
BR Thomas
Version: 0.19.20802 (Git)
Hash: f4279f1bea8377a7ef63f7f4c69b67159d498965
Qt version: 5.12.5
OCC version: 7.4.0
toms-macbook-air:~ tom$ /Applications/FreeCAD.app/Contents/MacOS/FreeCAD
# packages in environment at /Users/travis/build/FreeCAD/FreeCAD-AppImage/conda/osx_dev/APP/FreeCAD.app/Contents/Resources:
# Name Version Build Channel
arpack 3.7.0 hbb27dc6_1 conda-forge
blas 2.16 openblas conda-forge
boost 1.72.0 py38hbf1eeb5_0 conda-forge
boost-cpp 1.72.0 hdf9ef73_0 conda-forge
bzip2 1.0.8 h0b31af3_2 conda-forge
ca-certificates 2020.4.5.1 hecc5488_0 conda-forge
calculix 2.16 h3379aec_2 conda-forge
certifi 2020.4.5.1 py38h32f6830_0 conda-forge
coin3d 4.0.0 h3c06c15_1008 conda-forge
curl 7.69.1 h2d98d24_0 conda-forge
cycler 0.10.0 py_2 conda-forge
expat 2.2.9 h4a8c4bd_2 conda-forge
fastcache 1.1.0 py38h64e0658_1 conda-forge
flann 1.9.1 h3c234d5_1007 conda-forge
fontconfig 2.13.1 h6b1039f_1001 conda-forge
freecad 0.19.pre py38h7f341c1_115 freecad/label/dev
freecad.asm3 0.10.2 py_9 freecad/label/dev
freetype 2.10.1 h8da9a1a_0 conda-forge
future 0.18.2 py38h32f6830_1 conda-forge
gitdb 4.0.4 py_0 conda-forge
gitpython 3.1.1 py_0 conda-forge
gmp 6.2.0 h4a8c4bd_2 conda-forge
gmpy2 2.1.0b1 py38h4160ff4_0 conda-forge
hdf4 4.2.13 h84186c3_1003 conda-forge
hdf5 1.10.5 nompi_h3e39495_1104 conda-forge
icu 64.2 h6de7cb9_1 conda-forge
ifcopenshell v0.6.0 py38h128ab56_0 conda-forge
jinja2 2.11.2 pyh9f0ad1d_0 conda-forge
jpeg 9c h1de35cc_1001 conda-forge
jsoncpp 1.8.4 ha1b3eb9_1002 conda-forge
kiwisolver 1.2.0 py38ha0d09dd_0 conda-forge
krb5 1.17.1 h1752a42_0 conda-forge
libblas 3.8.0 16_openblas conda-forge
libcblas 3.8.0 16_openblas conda-forge
libclang 9.0.1 default_hf57f61e_0 conda-forge
libcurl 7.69.1 hc0b9707_0 conda-forge
libcxx 10.0.0 h1af66ff_2 conda-forge
libedit 3.1.20170329 hcfe32e1_1001 conda-forge
libffi 3.2.1 h4a8c4bd_1007 conda-forge
libgfortran 4.0.0 2 conda-forge
libiconv 1.15 h0b31af3_1006 conda-forge
liblapack 3.8.0 16_openblas conda-forge
liblapacke 3.8.0 16_openblas conda-forge
libllvm9 9.0.1 h7475705_1 conda-forge
libnetcdf 4.7.4 nompi_he461dc0_101 conda-forge
libopenblas 0.3.9 h3d69b6c_0 conda-forge
libpng 1.6.37 hbbe82c9_1 conda-forge
libpq 12.2 h489d428_1 conda-forge
libredwg 0.10.1.3266 py38hc829089_0 conda-forge
libssh2 1.8.2 hcdc9a53_2 conda-forge
libtiff 4.1.0 h2ae36a8_6 conda-forge
libwebp-base 1.1.0 h0b31af3_3 conda-forge
libxml2 2.9.10 h53d96d6_0 conda-forge
libxslt 1.1.33 h320ff13_0 conda-forge
llvm-openmp 10.0.0 h28b9765_0 conda-forge
lz4-c 1.9.2 h4a8c4bd_0 conda-forge
markupsafe 1.1.1 py38h64e0658_1 conda-forge
matplotlib-base 3.2.1 py38h1300a51_0 conda-forge
mpc 1.1.0 h4160ff4_1007 conda-forge
mpfr 4.0.2 h65ac59c_1 conda-forge
mpmath 1.1.0 py_0 conda-forge
ncurses 6.1 h0a44026_1002 conda-forge
netgen 6.2.1808 py38h65d59e6_1007 conda-forge
nspr 4.20 h0a44026_1000 conda-forge
nss 3.47 hc0980d9_0 conda-forge
numpy 1.18.1 py38h1f821a2_1 conda-forge
occt 7.4.0 hb9b6dc7_5 conda-forge
opencamlib 2019.07 py38h381bead_2 conda-forge
openssl 1.1.1g h0b31af3_0 conda-forge
pandas 1.0.3 py38h5fc983b_1 conda-forge
pcl 1.9.1 h3d0f52c_1005 conda-forge
pip 20.1 pyh9f0ad1d_0 conda-forge
pivy 0.6.6dev py38hd8f0d6a_0 freecad/label/dev
ply 3.11 py_1 conda-forge
pycollada 0.7.1 py_0 conda-forge
pyparsing 2.4.7 pyh9f0ad1d_0 conda-forge
pyside2 5.13.2 py38ha8f7116_2 conda-forge
python 3.8.2 hd5f0129_7_cpython conda-forge
python-dateutil 2.8.1 py_0 conda-forge
python_abi 3.8 1_cp38 conda-forge
pytz 2020.1 pyh9f0ad1d_0 conda-forge
pyyaml 5.3.1 py38h64e0658_0 conda-forge
qhull 2015.2 h04f5b5a_1000 conda-forge
qt 5.12.5 h514805e_3 conda-forge
readline 8.0 hcfe32e1_0 conda-forge
scipy 1.4.1 py38h38b60c6_3 conda-forge
setuptools 46.1.3 py38h32f6830_0 conda-forge
six 1.14.0 py_1 conda-forge
smesh 8.3.0.3 py38h7dac498_10 conda-forge
smmap 3.0.2 pyh9f0ad1d_0 conda-forge
solvespace 2.4.1 py38h281f984_0 freecad/label/dev
soqt 1.6.0 h02c1c16_0 conda-forge
sqlite 3.30.1 h93121df_0 conda-forge
sympy 1.5.1 py38h32f6830_3 conda-forge
tbb 2019.9 ha1b3eb9_1 conda-forge
tk 8.6.10 hbbe82c9_0 conda-forge
tornado 6.0.4 py38h64e0658_1 conda-forge
vtk 8.2.0 py38h5052d89_214 conda-forge
wheel 0.34.2 py_1 conda-forge
xerces-c 3.2.2 h8f8adb3_1004 conda-forge
xz 5.2.5 h0b31af3_0 conda-forge
yaml 0.2.4 h0b31af3_0 conda-forge
zlib 1.2.11 h0b31af3_1006 conda-forge
zstd 1.4.4 h4b3e974_3 conda-forge
FreeCAD 0.19, Libs: 0.19R20802 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
objc[9173]: Class FIFinderSyncExtensionHost is implemented in both /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit (0x7fffb2f4acd0) and /System/Library/PrivateFrameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride (0x124daacd8). One of the two will be used. Which one is undefined.
BR Thomas
Qt version: 5.12.5
OCC version: 7.4.0
I can confirm the message on opening a file. The message comes, after confirming a selected file, it occurs when opening via menu or icon.
It does not occur on cancelling. It occurs only once, i.e. it is not shown when opening another file.
