LCS and datum plane placement tricks
drmacro
Postby drmacro » Fri Apr 17, 2020 3:55 pm
Working on this exercise and I found placement of the plane to create surface A to be rather tricky.
I did it by forcing an edge in the first pad buy breaking a sketch line into two segments.
I love see how other would approach modeling this item:
Fig_8-49-2.FCStd
(71.33 KiB) Downloaded 12 times
My beginners, written treatise: Learning FreeCAD
kisolre
Re: LCS and datum plane placement tricks
Postby kisolre » Fri Apr 17, 2020 7:15 pm
Create a full topview sketch1, pad. Pocket the tail. Create a sketch at pad height, carboncopy sketch1 as construction geometry, create edge between A and B. Map sketch to that edge, cut front tip at 105 deg.
drmacro
Postby drmacro » Sat Apr 18, 2020 1:54 pm
Thanks.
I tried this. The attached file is my attempt. And it does get the job done.
But, the CC'd sketch geometry (in Sketch003) is now is used only as the source of the attachment. Correct?
Fig_8-49-3.FCStd
(58.27 KiB) Downloaded 8 times
Bance
Postby Bance » Sat Apr 18, 2020 3:10 pm
I just attached the DP to the base sketch with a rotation offset.
soidworksToolholder.FCStd
(68.84 KiB) Downloaded 9 times
kisolre
Postby kisolre » Sat Apr 18, 2020 3:44 pm
I would not use datum entities, because there are not multiple items to map to them and mapping is simple. For that front cut sketch use minimum edges to minimize computation difficulty.
Did you forget the round of the tail?
Here are my modifications to your file:
Funny thing is that I tried to use the top sketch as base for a Hole feature but this failed because it had also straight edges as normal geometry. If I remember correctly this worked in the past. Could anyone confirm?
OS: Windows 8.1 (6.3)
Version: 0.19.20477 (Git)
Hash: 7d8ab175a68e476427e6e337fe3099b52da49dc8
Python version: 3.6.8
Qt version: 5.12.1
Fig_8-49-3_kiss.FCStd
(63.35 KiB) Downloaded 11 times
drmacro
Postby drmacro » Sat Apr 18, 2020 5:05 pm
I see you changed the duplicate geometry in the CC'd sketch to construction lines. Just because or does that help computation as well?
Nope, just being lazy. I had it in earlier versions... :oops:
papyblaise
Postby papyblaise » Sat Apr 18, 2020 5:45 pm
Mine
porte outil.FCStd
(339.54 KiB) Downloaded 9 times
porte outil.PNG (10.92 KiB) Viewed 352 times
kisolre
Postby kisolre » Sat Apr 18, 2020 5:59 pm
To minimize the clutter when not editing the sketch. Only edges needed outside the sketch edit mode were left. Circles for the Hole feature, which failed, edges for sketch mapping.
freedman
Postby freedman » Sun Apr 19, 2020 8:38 pm
I like the kisolre design but instead I would have used a top datum plane for the threaded holes and cutter holder square cutout, I see these two features as dependent on each other. If someone later had to modify the model they would be glad these items were on a plane and sketched from above IMO.
This is a fun model, many different approaches. :)
drmacro
Postby drmacro » Mon Apr 20, 2020 1:56 pm
If you like that one, here is another:
https://forum.freecadweb.org/viewtopic.php?f=3&t=45487
