How to rotate multiple bodies until they touch the edge of a third - SOLVED
luggw1
Postby luggw1 » Sat Apr 18, 2020 5:22 pm
OS: Linux Mint 19.1
Version: 0.18.4.
Python version: 3.6.8
Qt version: 5.9.5
In the attached model, I'm modelling a small piece of the benchwork for my model railroad layout. The purpose is to model a bracket to hold a switch that will shut off track power on the lead to a drop-out section at a doorway. For orientation, the support and a section of the frame are on the right in the view that comes up when the file opens and the bridge with a support is on the left. The hinge is red.
My desire is to rotate the LeftHingeBody and BrigdeBody about a line passing through the axis of the hinge pin until some surface on the bottom of the bridge or bridge support just touches the lower right edge of the frame section. If I built the model correctly, it should be the right angled face of the bridge support that touches. FWIW, the bridge will not hang vertically if the model was built correctly. I frankly don't see how to do this in FreeCAD, but imagine it's simple enough to do.
If someone could provide some guidance in how to achieve this feat, I would be most appreciative.
Thanks
Bill Lugg
SwitchBrackets-HingeEnd.FCStd
(93.73 KiB) Downloaded 11 times
ppemawm
Re: How to rotate multiple bodies until they touch the edge of a third
Postby ppemawm » Sat Apr 18, 2020 6:57 pm
One way to do this is to place both bodies in a Part container so that they can move together using the Part > Placement properties as shown below:
You can obtain the center coordinates of the hinge axis by selecting an arc of the hinge then using this macro:
print Gui.Selection.getSelectionEx()[0].SubObjects[0].Curve.Center
OS: Windows 10 (10.0)
Version: 0.19.20391 (Git)
Hash: da92b8c242ead8cc106f480aa2eed0bac2edf10a
Qt version: 5.12.1
"It is a poor workman who blames his tools..." ;)
luggw1
Postby luggw1 » Sat Apr 18, 2020 9:02 pm
I attempted to use the macro and got the following syntax error:
'SyntaxError'>: ('invalid syntax', ('/home/luggw1/.FreeCAD/FindCenter.FCMacro', 1, 9, 'print Gui.Selection.getSelectionEx()[0].SubObjects[0].Curve.Center\n'))
Never having used macros before I'm not sure how to interpret this message other that to say that it didn't work.
Also, how does one access the dialog shown in your snapshot. I'm having trouble finding it.
Thanks
Bill Lugg
ppemawm
Postby ppemawm » Sat Apr 18, 2020 9:52 pm
I am not a programmer so hopefully someone else can help out with the syntax error.
In the meantime, try this one:
__Name__ = 'Measure Circle'
__Comment__ = 'Compute the radius of a circle by 3 points or a circular edge'
__Author__ = 'peepsalot, galou_breizh'
__Version__ = '0.10.0'
__Date__ = '2019-02-19'
__License__ = 'LGPL-2.0-or-later'
__Web__ = 'http://www.freecadweb.org/wiki/Macro_MeasureCircle'
__Wiki__ = 'http://www.freecadweb.org/wiki/Macro_MeasureCircle'
__Icon__ = 'MeasureCircle.svg'
__Help__ = 'Make a selection of 3 points or an edge and launch, or launch first'
__Status__ = 'Beta'
__Requires__ = 'FreeCAD >= 0.18'
__Communication__ = ''
__Files__ = 'MeasureCircle.png'
import FreeCAD as app
import FreeCADGui as gui
import Part
def get_global_placement(obj):
    try:
        # If obj is part of a Part or Body.
        return obj.getParentGeoFeatureGroup().getGlobalPlacement()
    except AttributeError:
        return app.Placement()
class MeasureCircle:
    """Report the radius and center of a circle
    This class will report the computed radius and center of a circle given 3
    vertices or a circular edge.
    Just select the vertices and the result will be shown in the Report View.
    Edges may also be selected and count as two vertices.
    A circular edge can also be selected.
    If two edges are selected the end vertex of the second edge is not
    used in the calculation.
    def __init__(self):
        self.points = []
        self.curve = None
        self.observer_needed = False
        self.get_elements_from_selection_ex()
        # We add the observer only if necessary.
        self.observer_needed = (self.curve is None)
        if self.observer_needed:
            gui.Selection.addObserver(self)
            app.Console.PrintMessage(
                'Select {} vertices on a circle\n'.format(
                    3 - len(self.points)))
    def addSelection(self, doc, obj, sub, pos):
        """Callback of the selection observer
        Do not rename.
        o = app.getDocument(doc).getObject(obj)
        # Get the shape of selected object, if any.
        try:
            shape = o.Shape
            app.Console.PrintMessage('Object is not a shape\n')
            return
        # Get the selected subshape.
        try:
            subshape = getattr(shape, sub)
        except:
                '"{}" is not a subshape of "{}"\n'.format(sub, shape))
            return
        if subshape.ShapeType == 'Vertex':
            self.add_point(o, subshape)
        elif subshape.ShapeType == 'Edge':
            self.on_edge(o, subshape)
        # Exit if we have enough points.
        if len(self.points) >= 3:
            self.on_three_points()
    def get_elements_from_selection_ex(self):
        for sel_object in gui.Selection.getSelectionEx():
            obj = sel_object.Object
            for subobject in sel_object.SubObjects:
                if type(subobject) == Part.Vertex:
                    self.add_point(obj, subobject)
                elif type(subobject) == Part.Edge:
                    self.on_edge(obj, subobject)
                    return
    def add_point(self, obj, v):
        """Add a point at the location of the selected vertex
        obj is the object the vertex belongs to. If obj belongs to a body, the
        body placement must be taken into account.
        placement = get_global_placement(obj)
        point = placement.multVec(v.Point)
        if point in self.points:
            # Don't allow duplicate points.
            app.Console.PrintWarning('Point already chosen, ignoring\n')
            return
        self.points.append(point)
    def on_edge(self, obj, edge):
        """Add either two points or a circle
        obj is the object the edge belongs to. If obj belongs to a body, the
        curve_type = type(edge.Curve)
        if curve_type == Part.Circle:
            self.on_circle(obj, edge)
        elif curve_type == Part.LineSegment:
            self.add_point(obj, edge.Vertexes[0])
            self.add_point(obj, edge.Vertexes[1])
    def finish(self):
        if self.curve:
            c = self.curve
            # line = Part.makeLine(c.Center, c.Center + c.XAxis * c.Radius)
            # obj = app.ActiveDocument.addObject('Part::Feature', 'Radius')
            # obj.Shape = line
            app.Console.PrintMessage('Diameter: {} mm\n'.format(2 * c.Radius))
            app.Console.PrintMessage('Radius: {} mm\n'.format(c.Radius))
                'Center: (X, Y, Z) = ({}, {}, {})\n'.format(
                    *list(c.Location)))
            gui.Selection.removeObserver(self)
    def on_circle(self, obj, edge):
        """Add a circle and finish
        obj is the object the curve belongs to. If obj belongs to a body, the
        edge = edge.copy()
        edge.Placement = edge.Placement.multiply(placement)
        self.curve = edge.Curve
        self.finish()
    def on_three_points(self):
        v1 = self.points[0]
        v2 = self.points[1]
        v3 = self.points[2]
        self.curve = Part.Arc(v1, v2, v3).toShape().Curve
        self.finish()
if __name__ == '__main__':
    MeasureCircle()
Select Part which contains the bodies. Select the Placement value field then the button with the ellipsis in the Property panel to expand the panel:
easyw-fc
Postby easyw-fc » Sat Apr 18, 2020 10:16 pm
After having placed the two shapes inside a Part container, you can use Mover from Manipulator WB
TheMarkster
Postby TheMarkster » Sat Apr 18, 2020 10:31 pm
I think you need to enclose the print parameters inside parentheses as of python version 3.
Try this instead:
print(Gui.Selection.getSelectionEx()[0].SubObjects[0].Curve.Center)
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
luggw1
Postby luggw1 » Wed Apr 22, 2020 2:20 pm
Thanks for all the help. These things did exactly what I was looking for.
Bill Lugg
