Make holes/pockets in the side of cylinders
drmacro
Re: Make holes/pockets in the side of cylinders
Post by drmacro »
V12StealthHunter wrote: Tue Dec 07, 2021 5:39 pm
drmacro wrote: Tue Dec 07, 2021 5:27 pm Why do you consider this a workaround?
The common approach is to draw a sketch or pocket on the surface. For tubes, this does not work and you are met with an error. Hence the method described in this thread does not feel like its a natural or intuitive workflow in FreeCAD. It feels like a workaround for an error that only if you visit the forums, you would learn how to workaround.
It is a perfectly legitimate workflow in the FreeCAD paradigm.
It is well documented that the FreeCAD paradigm does not include drawing sketches on non-planer surfaces.
It is possible to map sketches to curved surfaces. That is the province of the Curves workbench.
MangoJelly Solutions provides an excellent tutorial on this: https://youtu.be/ldPFgQsh3Nw
In 2013 sketches had always to be attached to plane faces or at one of the main planes. No offset. No angle. The so called "helper pads" were used to simulate what now can be done directly since v0.17.
V12StealthHunter
Post by V12StealthHunter »
Thanks @edwilliams16 that worked perfectly. Much better than the workaround.
edwilliams16 wrote: Tue Dec 07, 2021 5:58 pm
drmacro
Post by drmacro »
V12StealthHunter wrote: Wed Dec 08, 2021 1:24 am Thanks @edwilliams16 that worked perfectly. Much better than the workaround.
I guess I don't remember the process from 8 years ago. :mrgreen:
Can someone explain, other than the obvious functionality difference between old Part Design ways, what is so different?
Note, I e only had one cup of coffee so far today. :mrgreen:
jmaustpc
Post by jmaustpc »
drmacro wrote: Wed Dec 08, 2021 11:22 am
Basically, 8 years ago there was no attachment system, you had to only attach a sketch to a planar face of a solid, so no curved face attachment, no attachment offsets, also no Body object, and only the global axis system.
The vast majority of FreeCAD's current functionality did not exist back then.
8 years ago FreeCAD was used by dinosaurs, ... :D
Jim
To drill a sketch based 45° hole through a cylinder you had to add a helper construction at the top; external references existed only to created geometry.
Step 1: attach a sketch to the top and create a helper pad:
Step 2: attach a sketch to the helper pad and cut a 45° pocket:
Step 3: attach a sketch to the slanted face and create a pocket for the desired hole:
Step 4 (cleanup): Add a sketch to the helper pad, which cuts it all off:
No refine on object or feature level, only as an extra operation in OpenSCAD workbench or as a global preference.
jmaustpc
Post by jmaustpc »
chrisb wrote: Wed Dec 08, 2021 5:05 pm No refine on object or feature level, only as an extra operation in OpenSCAD workbench or as a global preference.
I am not sure if we even had Refine at all back then. We may have, as you say. We didn't when I first used FreeCAD. But we also didn't have Partdesign workbench at all then.
We have come such a very long way since that first time I opened FreeCAD and found it had almost no GUI tools at all. The first time I actually tried to model anything, I had to use a selection of about half a dozen Part primitives and the basic Boolean operations, all placement was by manually adjusting the placement properties of the primitives and the primitives could only be adjusted by manually changing their properties. But the first time I looked at FreeCAD must have been something like 5 years before the time we are talking about here, I suppose.
