Thanks for getting back to me.
Simpler example attached.
In the screenshot below, I get an error when I try to apply a fillet to the two selected arcs.
Techdraw dimension between line and arc tangent
Re: Techdraw dimension between line and arc tangent
- example.FCStd
- (55.15 KiB) Downloaded 12 times
The problem is the default radius of 1mm. It is too big for the adjoining faces. If you reduce it things should work just fine.
- example_Fillet.FCStd
- (72.5 KiB) Downloaded 11 times
Perfect! Thank you so much!
"Still on the freecad learning path...."
