Techdraw dimension between line and arc tangent
vectronic
Re: Techdraw dimension between line and arc tangent
Postby vectronic » Tue May 12, 2020 9:48 am
Thanks for getting back to me.
Simpler example attached.
In the screenshot below, I get an error when I try to apply a fillet to the two selected arcs.
Screenshot 2020-05-12 at 10.45.03.png (45.9 KiB) Viewed 43 times
example.FCStd
(55.15 KiB) Downloaded 2 times
Roy_043
Postby Roy_043 » Tue May 12, 2020 9:57 am
The problem is the default radius of 1mm. It is too big for the adjoining faces. If you reduce it things should work just fine.
example_Fillet.FCStd
(72.5 KiB) Downloaded 2 times
vectronic
Postby vectronic » Tue May 12, 2020 10:12 am
Perfect! Thank you so much!
"Still on the freecad learning path...."
