Techdraw dimension between line and arc tangent
Is there anyway in techdraw to define a measurement as indicate by the red arrow on the attached annotated screenshot?
The best attempt I have had is to insert a cosmetic index (by eye) on the arc, and then do a measurement from the line to the arc - less than optimal. However for some reason I am now experiencing a bug where I can't seem to add a cosmetic index, so can't even do this...
Thanks very much.
Nick
Thanks very much.
Nick
Re: Techdraw dimension between line and arc tangent
You can do this in the model by creating appropriate seams. TechDraw is probably the wrong place to add such stuff (normal to circle and an edge - or should it be the center point of the line?).
- Snip macro screenshot-3613fe.png (26.26 KiB) Viewed 1393 times
- wandererfan
@chrisb has it. When I need to do something tricky, I add construction geometry in 3D, then include it as Source for the View.vectronic wrote: ↑Sun Apr 26, 2020 11:21 pm Is there anyway in techdraw to define a measurement as indicate by the red arrow on the attached annotated screenshot?
You can always hide the construction lines with the line decorator.
details please. I don't get a lot of feedback on the cosmetic functions unless they crash.However for some reason I am now experiencing a bug where I can't seem to add a cosmetic index, so can't even do this...
With pleasurewandererfan wrote: ↑Mon Apr 27, 2020 12:59 am details please. I don't get a lot of feedback on the cosmetic functions unless they crash.
I have recorded my actions here to add a cosmetic vertex -> maybe I am doing something wrong? As far as I can see this isn't desired behaviour and I'm sure it didn't work like this previously.
https://www.loom.com/share/2a25b6f0fae9 ... b08f59a79b
I attach the cad file before the recording and after the recording.
Thanks
Nick
- example.FCStd
- (211.21 KiB) Downloaded 20 times
- example-after.FCStd
- (211.62 KiB) Downloaded 20 times
I have attached a screenshot of the sketch used to drive the geometry where I have a tangent construction line. I am using this to constrain the distance to the line. This constraint distance is what I am trying to expose in the techdraw drawing.wandererfan wrote: ↑Mon Apr 27, 2020 12:59 am @chrisb has it. When I need to do something tricky, I add construction geometry in 3D, then include it as Source for the View.
I must admit I am a bit clueless on how to proceed with your suggestion. I think instead of using a construction line, I think I would need to use external geometry in the sketch, but there is no external geometry to reference in this case.
The construction line done has a point on circle constraint as well, but I believe because it is a point on a circle, there is no edge at this point which appears in the geometry.
If you could provide any suggestions for how I should proceed it would be much appreciated.
Nick
The construction line doesn't contribute to the geometry as seen from the outside. You can create the circle from two arcs, that's what I did in my example. Similar with the line: split it in two tangential lines of equal length.
Thanks very much! Understood. I will give it a go.
- wandererfan
Should be fixed by git commit 1fc2e755dd. Was not handling secondary views in projection groups properly.
Thanks for reporting!
Thanks for implementing!
I have taken the useful advice in this thread and re-done the sketch as two arcs and this indeed lets me add the desired measurement in techdraw. However it has has lead me to another unexpected issue in part design....
Now that the 'stud' is created by a pad of two arcs (instead of a circle) it seems I am unable to apply a fillet on the top curved edge of the 'stud'. I assume this is because a fillet on an arc is not possible, but it is allowed on a full circle...?
See screenshot.
Any suggestions how to paint myself out of this corner?
Could you please provide your (example) file?
Thank you very much!
Regards / Viele Grüße
Max
Max
