Help with using ruler
sonicnuance
Postby sonicnuance » Wed Sep 25, 2013 4:21 pm
I'm having difficulty measuring distances with the "measure distance" tool (ruler icon in the Part Workbench). Is there a way to constrain the tool to measure in only in the xy plane and/or perpendicular lines? I keep getting diagonal measurements when I want the distance between two parallel lines (for example)
Thanks
PS
I'm using OSX 10.7 and FreeCAD 0.13
NormandC
Re: Help with using ruler
Postby NormandC » Wed Sep 25, 2013 4:56 pm
No, it's not possible to constrain it.
I suggest you use the Draft Dimension tool instead, it's a lot more flexible and you can constrain it.
bejant
Postby bejant » Wed Oct 02, 2013 1:37 am
I think it would be a worthwhile feature so I submitted this ticket.
sonicnuance
Postby sonicnuance » Wed Oct 02, 2013 2:24 am
bejant wrote:I think it would be a worthwhile feature so I submitted this ticket.
Thank you for taking the initiative
ewanfowler
Postby ewanfowler » Sat Oct 01, 2016 9:25 am
I think you can double click the measurement in the Model pane and see the xyz coordinates of each point so the distance will be the difference. There's probably a better tool for this though as already mentioned
NormandC
Postby NormandC » Sun Oct 09, 2016 8:16 am
Hello Ewan,
A (belated) welcome here.
You replied to a very old topic. :D A whole set of measurement tools was added since. It is available in the Part workbench.
Std_Measure_Menu
Relating to bejant's bug ticket, the bug tracker was since moved from Sourceforge, so here's the updated link: issue #1263.
bejant
Postby bejant » Sun Oct 09, 2016 1:27 pm
Norm, I also replied to your note on the ticket, I think it should be closed.
