Scale and rotation in TechDraw don't work for me
lalebarde
Postby lalebarde » Sun May 24, 2020 6:21 pm
I am new on FreeCAD and have the last version 0.18. I am trying to use TechDraw since I need to print some design. I have followed two tutorials [https://wiki.freecadweb.org/Basic_TechDraw_Tutorial/en, https://wiki.freecadweb.org/Manual:Gene ... D_drawings].
My understanding is:
  • From a template, I can layout my design with all the views I want
  • When I select both an object in the 3D view and a page, then click on Insert view in page, it inserts it into the page as it is in the 3D view
  • I can then access the parameters of the wiew projected in the page via the tree list, and tune the position of the view in the page, its orientation, scale, and even modify the projection from the 3D model
So I have performed a test, and unfortunately, only position change works, not the scale, nor the orientation, nor the 3D projection.
In the following basic example, I want to scale at 0.5 and rotate 90° to fit the template, but nothing happens. Obviously, I have performed some mistakes, but where?
Strange, after having added title and hatch on a face, the scale and rotation has been eventuelly taken inti account :
Roy_043
Re: Scale and rotation in TechDraw don't work for me
Postby Roy_043 » Sun May 24, 2020 8:58 pm
The blue markers in the Tree view in your first image indicate that the document requires a recompute (see Std_Refresh).
lalebarde
Postby lalebarde » Sun May 24, 2020 10:03 pm
That has not solved the problem. That said, after the refresh, the view has been lost, I had to rebuilt it.
wandererfan
Postby wandererfan » Sun May 24, 2020 11:45 pm
If you change the Scale on a View, but the ScaleType is still set to Page, the Page scale will override the View scale.
For Rotation or Direction, change the parameter in the property editor, then press Recompute.
I don't recall any issues with disappearing Views in v0.18. Try View All? Maybe it has moved out of the visible window?
lalebarde
Postby lalebarde » Mon May 25, 2020 7:16 am
I was looking for the redraw button which has been removed in version 0.18 but reimplemented in v0.19. Eventually, one need to use the Refresh button and then it works.
Many thanks for your help.
