Move imported DXF - Import Options, lassoo etc
sjb
Postby sjb » Mon May 25, 2020 9:48 am
Folowing Yorik's "Freecad A Manual" example, I tried the DXF import. Being unable to find a way to "lassoo" the resulting "cooktop" (hob) objects, I tried creating a group. This might work using the "Move" tool, but here a simple "mouse drag" would be quicker.
Should I ammend the import options, eg. "Join Geometry" to follow this example? The example text simply says
"Insert the two DXF files, and move them to a suitable location on the tabletop"
DXF Import.png (138.44 KiB) Viewed 139 times
Syres
Re: Move imported DXF - Import Options, lassoo etc
Postby Syres » Mon May 25, 2020 10:28 am
In the 3D view, Shift+B to box select the DXF(s) to be moved and then Draft>Move, click a vertex on the DXF and move the mouse cursor to the desired location is the procedure I would use.
sjb
Postby sjb » Mon May 25, 2020 3:13 pm
Ah... "Shift+B" - Thanks!
