[sketcher feature request] auto constraints symmetry
nic
Postby nic » Mon May 25, 2020 2:40 pm
Hello
I hope I'm in the good sub-forum.
using the symmetry tool in the sketcher works really good. But each time, I find myself constraining the newly created nodes using ... symmetry constraints.
Wouldn't it be possible to automatically create those constraints?
[edit] typo in title
adrianinsaval
Re: [sketcher feature request] auto constraints symmetry
Postby adrianinsaval » Mon May 25, 2020 3:59 pm
+1
Postby Kunda1 » Mon May 25, 2020 5:27 pm
Moved to Help subforum
openBrain
Postby openBrain » Mon May 25, 2020 5:36 pm
Feature requests generally are in "open discussion". ;) :lol:
@OP : could you give some details about how it would work and be used ?
vocx
Postby vocx » Mon May 25, 2020 5:44 pm
How would the sketcher know that you want a symmetric constraint and not just a regular node?
nic
Postby nic » Mon May 25, 2020 8:04 pm
well, i don't really get your question. When I make an "item" (edge, circle, etc.) symmetric against a given axis, I would expect that the "created" nodes would be automatically constrained as symmetric
eg.
starting from this fully constrained sketch :
current behavior result is :
I would rather prefer (because i always found myself correcting the result in this way) :
Also, as far as I remember, (and although it is not necessarily a good reference), this is how CREO's sketcher behave
Postby chrisb » Mon May 25, 2020 8:50 pm
So you think all points should be made symmetric. To be honest: that's not how I would constrain it, if I had to do it all manually. I would indeed create a rectangle and prefer vertical and horizontal constraints and add only one or two symmetries.
vocx
Postby vocx » Mon May 25, 2020 11:33 pm
Well, you didn't provide this explanation in your first post, so you left us wondering what you actually meant.
I think those operations in the toolbar duplicate the selected sketch but don't add further constraints. Probably adding constraints at that time is not good for the sketcher solver, so that's why it's left to the user to apply the constraints explicitly later.
nic
Postby nic » Tue May 26, 2020 6:57 am
@chrisb
well, that would work for the dummy example sketch. Making symmetry constraints has the advantage to be a generic solution, and to maintain the ability to change the initial shape, while keeping symmetry up to date.
Maybe we could keep the current behavior by default, and propose the "auto-symmetry" as an option?
actual behavior :
expected behavior :
@vocx
yes, maybe it's not possible to code that, but as you can see in my last example, the sketcher looks able to add some constraints by itself, although they are maybe not the more relevant ones...
But as I said above, we could keep the current behavior as a default workflow, while letting the user selecting the "auto-symmetry". What do you think?
drmacro
Postby drmacro » Tue May 26, 2020 1:16 pm
Just a general comment, not opinion on the proposed functionality.
I see many, adding geometry to sketches that would (in many cases) create less cluttered and easier to constrain sketches if the feature (i.e. hole, slot, etc.) were left to subsequent mirror operations. There are of course times when the shape being designed needs to be symmetric about something (axis, other geometry, etc.). In the example given (two obrounds at an angle symmetric about an axis), I'd sketch and constrain one, then pocket and mirror. Thus saving a several constraints. (Note: not knowing what the rest of the sketch looks like, I may do it differently.)
Now it may be that it's just my way of thinking out what needs to be sketched and modeled. But, I tend to like to keep my sketches as simple as possible.
Of course, YMMV, as they say. :roll:
My beginners, written treatise: Learning FreeCAD
