Deleting constraint causes warning: Delete: Selection not restricted to one sketch and its subelements
I get a warning if I delete the point-on-object constraint in the attached sketch:
OS: macOS High Sierra (10.13)
Version: 0.19.21329 (Git)
Hash: 2330eef823b32ac412d839031cc174353a76b013
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
Qt version: 5.12.5
OCC version: 7.4.0
- warning.FCStd
- (3.32 KiB) Downloaded 42 times
Re: Deleting constraint causes warning: Delete: Selection not restricted to one sketch and its subelements
I don't get this warning.
The relevant code is
For me the size of "selection" is always 1 so it doesn't print the warning.
void ViewProviderSketch::deleteSelected()
std::vector<Gui::SelectionObject> selection;
selection = Gui::Selection().getSelectionEx(0, Sketcher::SketchObject::getClassTypeId());
// only one sketch with its subelements are allowed to be selected
if (selection.size() != 1) {
Base::Console().Warning("Delete: Selection not restricted to one sketch and its subelements");
return;
// get the needed lists and objects
const std::vector<std::string> &SubNames = selection[0].getSubNames();
if(SubNames.size()>0) {
App::Document* doc = getSketchObject()->getDocument();
doc->openTransaction("delete sketch geometry");
onDelete(SubNames);
doc->commitTransaction();
You must have some serious static causing these faults
But seriously I can't replicate the error using:
OS: Windows 7 SP 1 (6.1)
Version: 0.19.21325 (Git)
Hash: 2cb9b147f13419f019f9808ace21d3d2ceae99c5
Python version: 3.6.8
Qt version: 5.12.1
I have retried with a plain vanilla config and still get the warning. It doesn't matter if I select the constraint in 3D view or in the constraints list.
The warning does not occur on my Ubuntu box, but it occured in these versions as well, so it was present since quite some time. Can another Mac user check this?
Version: 0.19.21125 (Git)
Hash: 40600a55c2fe71ff589be677f6e427ccc937d003
Qt version: 5.12.5
OCC version: 7.4.0
OS: macOS 10.13
Version: 0.18.16146 (Git)
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
Qt version: 5.12.5
OCC version: 7.4.0
OS: macOS 10.13
Qt version: 5.6.2
Sorry for bringing up this thread again. But I get this warning all the time. Has this issue been addressed?
Very often when I try to delete some constraint after the solver points out some redundancy, I cannot delete this constraint, and when trying keep getting this warning. The only way to get rid of the constraint is leaving the sketch editor (ESC key) and re-enter it, then I can delete it fine.
Cheers Peter
Cheers Peter
Version: 0.19.23578 (Git)
Hash: 50c3cbf00579dc4941ca743c25720d016b0453ce
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
I have a vague sense that we did get this worked out in the end -- it was something like the selection system was getting confused, and the current selection somehow set to something that was not the sketch? I don't remember when that was, though -- is there a newer version you can update to and re-test?
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.8
Qt version: 5.12.5
OCC version: 7.4.0
I get the warning deleting either in the list or by selecting in the view. The constraint is successfully deleted.
Qt version: 5.12.5
OCC version: 7.4.0
OK, so much for that! The fix I'm thinking about was before that commit, so must not address this issue.
Hi all,
sorry to reopen this discussion, but somebody found the solution to this warning?
I am on two mac intel & M1 with three different version of Freecad and this alert is coming every-time when one element (any) from sketch is deleting.
Is it something dangerous?
I uninstall and reinstall Freecad with the same result.
one of the versions:
thanks for your help!
OS: macOS 10.16
Version: 0.20.2.29603 (Git)
Branch: (HEAD detached at 0.20.2)
Hash: 930dd9a76203a3260b1e6256c70c1c3cad8c5cb8
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
* Movie 2023.6.10
* ProDarkThemePreferencePack 1.0.0
* A2plus 0.4.60i
* fasteners 0.4.24
* ExtremeProLight 1.6.0
* ExplodedAssembly
* Help 1.0.3
* Assembly4 0.12.4
* Assembly3 0.11.4
Update to the latest version and see if it has been fixed. If there has been a recent fix it will never get back ported to 0.20.
