[FEATURE REQUEST] Life-size view ?
Hello FC people.
How can I display a life-size view of a part/assembly (normal projection) ? After a length unit is chosen, a screen having an immutable pixel size, it's just a question of doing a ratio to show a life-size representation, but how achieve this ?
Thank.
Thank.
- papyblaise
Re: Life-size view ?
not sure but I think it's depend of the size of your screen (laptop or screen of the stadium) and the definition of your's HD or older
But you can verify this by afixe the grid with 10mm of space of lines and use your meter directly on
Yes, for sure.
For example, considering a typical 0.25 mm square pitch, the user working with millimeter as unit. So obviously a 15 mm long edge requires 60 pixel, but the routine in charge of the final display must be informed of the screen specifications.
Should be easily scripted.
I even think it might deserve being set as a feature, and put into the view menu (along side "fit all").
Re: [FEATURE REQUEST] Life-size view ?
Thanks for being awesome, kisolre.
It would be a nice feature. If no one else takes this on, I might look into a python solution later this year. Perhaps the issue will be making it multi-platform but I know DPI is also available on Windows systems. I expect MAC to closely follow the Linux side. I'm sure we can figure it out.
DPI of the monitor and scale of the object view is all that should be needed to calculate the zoom ratio.
Here's an article on finding, testing, and potentially correcting the DPI register on a Linux system.
https://winaero.com/blog/find-change-screen-dpi-linux/
IMO you shouldn't bother yourself too much with the details. Qt already has everything needed, eg. in the QScreen class.TomB19 wrote: ↑Wed Jun 10, 2020 6:52 pm Here's an article on finding, testing, and potentially correcting the DPI register on a Linux system.
I'm actually confused by this discussion.fcaduser wrote: ↑Mon Jun 01, 2020 12:27 pm Hello FC people.
Thank.
Do you actually want to hold a 30 cm ruler up to the screen and measure 30 cm?
Thank you, Mr. Brain!
Is it as simple as this?
from PySide import QtGui
dpi = QtGui.QScreen.logicalDotsPerInch();
