Black background on constraints
This black background looks something wrong for me.
Is this a new feature or a bug?
OS: Ubuntu 20.04 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.21280 (Git) AppImage
Hash: 6f3160db3e88733536c7eaf97ad7d6ebd21baccd
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Qt version: 5.12.5
OCC version: 7.4.0
Re: Black background on constraints
It tends to appear sometimes. It disappears by itself. It seems to be a "bug" but not a serious one. Some sort of rendering artifact.
Werner commented on this. It seems to be that some display buffers run out of memory and use some fallback solution.
I haven't seen this, but I have seen on occasion all the points in a sketch turn black. Sometimes when it happens it goes away by zooming in and out.
hi, i found same problem when selected render :
edit ▻preferences ▻ Display ▻ render : Anti-aliasing : Line Smooth
but selected "MSAA 2X~8X" will not happen.
you can try it.
edit: forgotten to say that test in arch linux 5.12.15, freecad 0.19 with intel uhd620
and i test again, if a saved file that it's drawing has the problem, changed anti-aliasing to other can display as normal.
if a saved file made a drawing that original display as normal, changed to 'Line Smooth' not reproduce black background problem.
you can try it.
- Shalmeneser
I confirm.
I confirm.
Chrisb, do you know something that we can do to check this statement (where the buffers run out off memory) when I see this black-bg issue again?
I am not seeing this issue anymore.
My machine has a lot of RAM (32GB), maybe this is not the problem for me, unless the display uses a different, less available memory or maybe that time I was running to many things at the same time.
I don't know how to provoke the phenomenon, but I haven't seen it for quite some time. Perhaps the different library versions used have improved the situation.leoheck wrote: ↑Sun Aug 15, 2021 7:11 pm Chrisb, do you know something that we can do to check this statement when we see this black-bg issue? I am not seeing anymore anymore. My machine has a lot of RAM (32GB), maybe this is not the problem for me, unless the display uses a different, less available memory or maybe that time I was running to many things at the same time.
As commented kevin_fc, this problem appears if selected "Line Smooth" anti-aliasing mode:
Edit>Preferences>Display>Rendering: Anti-aliasing=Line Smooth
After setting to another mode - problem disappears.
My system:
Linux Mint 19.1 (Mate desktop), 4.15.0-158
VGA Intel UHD 630
FreeCAD 0.19 (14555)
My system:
VGA Intel UHD 630
Can you please retry in 0.20?
