Why body get empty?
Why body get empty?
How to explain the body is emptying when when I drag the cube inside the part container?
OS: Windows 10 (10.0)
Version: 0.19.21280 (Git)
Hash: 6f3160db3e88733536c7eaf97ad7d6ebd21baccd
Python version: 3.6.8
Qt version: 5.12.1
Locale: French/France (fr_FR)
Qt version: 5.12.1
- Capture.JPG (17.95 KiB) Viewed 1266 times
- test.FCStd
- (14.04 KiB) Downloaded 28 times
Re: Why body get empty?
Expand the body and then do the drag. Not sure what your asking.
Confirmed, objects inside the Body get removed when dropping the Cube into the Part.
Version: 0.19.21329 (Git)
Hash: 2330eef823b32ac412d839031cc174353a76b013
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Qt version: 5.12.5
OCC version: 7.4.0
I don't see anything removed in my 0.18 or 0.19.20477.
I see it on this version, too:
Version: 0.18.16093 +17 (Git)
Branch: (HEAD detached at 0.18.1)
Python version: 2.7.14
OCC version: 7.2.0
So it predates the link merge.
OCC version: 7.2.0
Post your full information as it might be a windows-related issue only.
Maybe a config file issue...
Nothing weird on these machines.
OS: Windows 7
Version: 0.18.16085 (Git)
Hash: 6323069cbbda5ac71dff073f15cc632d8a1f3ea3
OCC version: 7.2.0
Version: 0.19.20477 (Git)
Hash: 7d8ab175a68e476427e6e337fe3099b52da49dc8
Qt version: 5.12.1
OS: Windows 7
OCC version: 7.2.0
Qt version: 5.12.1
If I remove the support to the datum lines from the box then everything works as expected.
I am guessing that the box is improperly linked to the datum lines inside the body (red arrows on the dependency graph) and when the box is moved it drags its support (datum lines) with it. The other elements in the body that are linked to the datum lines go along for the ride.
First thing to do is get rid of the errors. There may be a bug, but start with a clean model first.
OS: Windows 7 SP 1 (6.1)
Qt version: 5.12.1
Gene
Qt version: 5.12.1
Gene
The issue occurs just when moving inside. If you remove the supports before then grab it inside, there're no problem. After that if you re-link the cube, still no problem. But if you remove it from the part and re-put inside, the bug occurs again.
This bug still here.
move the box inside the part container....the body get empty.
Version: 0.20.26761 (Git)
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
- Body_empty.FCStd
- (11.65 KiB) Downloaded 19 times
