Assembly4 Master sketch
sjam986
Postby sjam986 » Sat Jun 06, 2020 4:54 am
Assembly4 Master sketch problem:
I have created a very simple model of an engine crankshaft - no parts or bodies yet - just an Assembly4 model with variables and a master sketch with one line from the origin to a point 23 mm radius on the YZ plane, 30 deg acw from the Y axis. The crankshaft rotates about the X axis and the Z axis is vertical. Hence the master sketch is on the YZ plane.
The variables are Angle_crank = 30 deg and R_main = 23 mm.
I selected the master sketch and in Map Mode I selected LCS_Origin as the attachment with mode Object's YZ plane. In the master sketch the new Z axis is along the line from the origin.
I then selected the model, created a new coordinate system LCS_crank with first attachment 'Vertex' - 'Sketch_master:Vertex1' and second attachment 'Line' - 'Sketch_master:Edge1' with mode 'Align O-Z-Y'.
When animated the line rotates as it should in the YZ plane but the axes swap over as the new Y axis passes the old Z axis.
If I follow the same process with the sketch on the XY plane, everything works perfectly. However, with the sketch in the YZ plane, It doesn't work.
What am I doing wrong?
OS: Windows 10 (10.0)
Version: 0.19.21097 (Git)
Hash: a5ab09aa0941cc945e59848897b160f8cbfc0831
Python version: 3.6.8
Qt version: 5.12.1
Locale: English/New Zealand (en_NZ)
Zolko
Re: Assembly4 Master sketch
Postby Zolko » Sat Jun 06, 2020 11:20 am
Since you only specified 1 axis, FreeCAD must infer the second axis, and it does so according to some algorithm that you can't know, and that swaps orientation whenever it feels comfortable about it.
So try the reverse order : attach LCS_crank to LCS_Origin, in its AttachmentOffset set the rotation angle around the X axis to Angle_crank. Create a Datum Point and attach it to LCS_crank, and offset it by R_main in the Z direction (this point will be the rotation reference). Then, in your master sketch, import this point as external feature, and draw the rest.
sjam986
Postby sjam986 » Sun Jun 07, 2020 7:27 am
That worked. So far so good.
I could not get the Datum point etc. to work. I lost count of the number of permutations I tried!
However, creating LCS_arm in the crank_body and then using 'Place linked Part' to link crank_body LCS_arm to parent LCS_crank worked and correct rotation resulted.
So, many thanks for your help - I am inspired to do more!
Reason: fixed broken quote tag
