Can't join manifolds
raidho36
Postby raidho36 » Sun Jun 07, 2020 10:52 pm
I'm trying to make a fan manifold to blow across 5 small heatsinks (3d printer cooling) but none of the methods I tried result in usable geometry. I've tried lofting solid pipes and using part thickness, that didn't work at all. I've tried lofting sketches with built-in thickness but they won't join using Connect Walled Objects function. I've tried making additive and subtractive lofts to produce walled pipes but these won't join either. I've tried making all the additive pipes and then carve them using subtractive pipes, but those wouldn't even generate the manifolds to begin with, it would fail after the first one. Finally, I've tried making lofts one per body and join them using boolean operations, but those either fail completely or produce invalid results.
fan manifold.FCStd
(136.97 KiB) Downloaded 35 times
Re: Can't join manifolds
Postby chrisb » Mon Jun 08, 2020 1:29 am
I guess you cannot make a boolean union of these due to coplanar issues.
I would recommend to model this in one body.You can try thickness, but as that is one of the most picky tools I would not rely on it. Then you have to model the manifold a second time with slightly smaller subtractive sweeps.
raidho36
Postby raidho36 » Mon Jun 08, 2020 1:32 am
Yes I tried that, it did not work. When modeling it in one body, it fails almost immediately producing the same invalid results as if I modeled them separately and used boolean union.
Postby chrisb » Mon Jun 08, 2020 1:34 am
Can you upload that model?
raidho36
Postby raidho36 » Mon Jun 08, 2020 1:35 am
It's in the OP.
TomB19
Postby TomB19 » Mon Jun 08, 2020 3:39 am
As I understand it,you can only export the active body. You have multiple bodies so you won't be able to export a combined mesh.
I suspect that's why Chris is asking for your version with a single body.
Postby chrisb » Mon Jun 08, 2020 6:09 am
You can select more than one body for export. What I have seen in my 3d print slicer is that they are treated like a union.
Correct!
fc_tofu
Postby fc_tofu » Mon Jun 08, 2020 8:24 am
Tiny intersected details prevent boolean operation success. (red-marked) The reason is same as @chrisb called "co-planar" issue.
I tried export your model as STEP and OBJ, and tried union them in another CAD, suface modeling app, Blender, all resulted in failure.
So my feeling is that, "co-planar" and similar issues are not FreeCAD only, but related to all Boolean/CSG workflow in all 3D apps.
My workaround is cut the "neck" off. Rebuild neck with loft. Then reunion them together.
drmacro
Postby drmacro » Mon Jun 08, 2020 1:04 pm
Just for reference:
Exhaust-3_test.FCStd
(587.85 KiB) Downloaded 15 times
My beginners, written treatise: Learning FreeCAD
Postby chrisb » Mon Jun 08, 2020 1:12 pm
Part Pipe connect is worth a try too.
