[Bug#4382] Error position in Array when "Link Array" checked off
fc_tofu
Postby fc_tofu » Wed Jun 10, 2020 1:49 pm
Summary
DraftWB, Array operator, when "Link Array" option checked off, error appear on viewport.
Reproduce
1. Startup FreeCAD, switch to DraftWB
2. Draw a circle
3. invoke "Array" operator
4. Task panel of "Array", check off "Link Array", OK
5. Observe on viewport, strange points appear and placement of array instance is wrong.
Strange points seems center of circles, the only vertex of circle. So, the issue means vertices and edges are separated after non-link Array.
In case of "Link array" checked on, the result looks right in viewport. Then after Downgrade, same result (as Reproduce step 5) happens.
Recompute, restart FC, restart PC, reset "user.cfg" donn't help in both cases.
OS: Windows 10 (10.0)
Version: 0.19.21329 (Git)
Hash: 2330eef823b32ac412d839031cc174353a76b013
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Chinese/China (zh_CN)
Tracker:
issue #4382
ps.
Summary on 2020-06-28.
Conditions of this bug:
1. OCCT 7.4 (not 7.3)
2. Link array = False (not True)
3. Make face = False (not True)
4. FreeCAD 0.19 (not 0.18)
non_linkarray.FCStd
(5.53 KiB) Downloaded 11 times
vocx
Re: DraftWB, error in Array when "Link Array" checked off
Postby vocx » Wed Jun 10, 2020 4:24 pm
No error here.
OS: Ubuntu 18.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.21562 (Git)
Hash: 11a2b948ea55b19efe7515f730035027a7822e06
Python version: 3.6.9
Qt version: 5.9.5
_obj_ = Draft.make_ortho_array(App.ActiveDocument.Circle, v_x=FreeCAD.Vector(100.0, 0.0, 0.0), v_y=FreeCAD.Vector(0.0, 100.0, 0.0), v_z=FreeCAD.Vector(0.0, 0.0, 100.0), n_x=3, n_y=1, n_z=1, use_link=False)
_obj_.Fuse = False
Draft.autogroup(_obj_)
TheMarkster
Postby TheMarkster » Wed Jun 10, 2020 4:36 pm
Seems to work as expected here.
Qt version: 5.12.5
OCC version: 7.4.0
My FreeCAD video series on youtube: https://www.youtube.com/c/mwganson
fc_tofu
Postby fc_tofu » Wed Jun 10, 2020 4:58 pm
I'm using Conda build, what about you. (From hash number, it seems you are using conda build also.)
Thank you and @vox.
fc_tofu
Postby fc_tofu » Wed Jun 10, 2020 5:05 pm
_obj_.Fuse = False
I tested this code. Same error happens.
TheMarkster
Postby TheMarkster » Wed Jun 10, 2020 5:26 pm
It is a conda build. If I create circle and run the code I get no errors.
Snip macro screenshot-f8f566.png (151.36 KiB) Viewed 503 times
Syres
Postby Syres » Thu Jun 11, 2020 8:27 am
What I've not seen mentioned is that if you make the Circle (or any other 2D object) to Make Face=True then the array is corrected, I hope this helps narrow down the bug. So far I've not found any issues with applying an array to a 3D model, thankfully and also the AppImage equivalent to this Windows Conda build does not produce the bug which was a little surprising.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.21514 (Git)
Hash: 89ddab33f692a9bd739171689f9ab0eb58d64b35
Qt version: 5.12.5
OCC version: 7.4.0
fc_tofu
Postby fc_tofu » Thu Jun 11, 2020 9:01 am
Thank you for point out a key factor.
1. If "make face" is toggled on when drawing circle, the problem won't happen after Array operation.
2. When "make face" option of circel is toggled off, the problem happen back again.
The same result happen to other 2D Draft objects, such as rectangle.
This issue doesnot happen to 3D objects, such as Part primitive cube.
array_2d_face.FCStd
(5.58 KiB) Downloaded 8 times
fc_tofu
Postby fc_tofu » Thu Jun 11, 2020 11:50 am
Please redo your test with "Make Face" =false.
vocx
Postby vocx » Thu Jun 11, 2020 1:20 pm
No error with or without MakeFace true.
pl=FreeCAD.Placement()
pl.Rotation.Q=(0.0, 0.0, 1.5308084989341915e-17, 1.0)
pl.Base=FreeCAD.Vector(-141.9844199134889, -48.87504491348892, 0.0)
circle = Draft.makeCircle(radius=19.33585978294259, placement=pl, face=False, support=None)
Draft.autogroup(circle)
FreeCAD.ActiveDocument.recompute()
_obj_.Fuse = False
