Importing rcs-data from drone scan
thschrader
Postby thschrader » Thu Jun 18, 2020 7:18 am
a colleague asked me if I can import a 600 MB-file from a drone scan in FC.
I cant find rcs in the import-filter. Maybe converting rcs to another format before?
Thanks for help.
Thomas
example revit:
https://knowledge.autodesk.com/support/ ... C-htm.html
jeno
Re: Importing rcs-data from drone scan
Postby jeno » Thu Jun 18, 2020 3:48 pm
Thanks for help.
Thomas
Hi Thomas,
it is not surprising that you can't find a import-filter. It is a Autodesk Recap file. Afaik it is closed source.
A way to go would be to export to XYZ (pure point data) or PTS (point data plus color data). This data could be imported into Meshlab or CloudCompare. Further processed in a triangle-mesh it can be imported in freecad.
But if I look at the filesize (600 Mbyte!) I tend to say it is necessary to downsample the data depending on your needs.
Cheers
thschrader
Postby thschrader » Thu Jun 18, 2020 4:22 pm
Hi Thomas,
Jeno thanks!
Yes, after some hours google-time looking for converters my boss decided:
We must buy Recap! :lol:
BTW: the scan was done by Deutsche Telekom. Experimental, scanning cell-phone towers
for CAD-usage. Nobody wants to climb up the tower for doing measurements ;)
Lets see if Recap has export functions for 3D to load in FC.
jeno
Postby jeno » Thu Jun 18, 2020 6:03 pm
Hi Thomas,
Jeno thanks!
Your welcome.
I have my doubts ;) Beware, cause they'll try to pull you into the Autodesk universe.
cheers
Postby Kunda1 » Thu Jun 18, 2020 6:30 pm
Is there any way to get the original drone data to export in to another point cloud format? (since rcs is proprietary)
I remember something about @HakanSeven12 importing an impressively large point cloud file in to Geomatics WB (or was it Trails WB)
HakanSeven12
Postby HakanSeven12 » Thu Jun 18, 2020 6:40 pm
If your file is a text format you can use trails. If not you need to convert it to text format.
thschrader
Postby thschrader » Sat Jun 20, 2020 8:43 am
The original rcs-file has a size of 615 MB because of scanning the complete forrest around the tower :lol:
In the end I could import the tower to FC.
My Workflow:
In Recap: export data as pts (simple text-file)
Rename file extension from pts to txt, open text editor.
Convert decimal-point to comma.
Open txt in Excel, get rid of line 1 and columns 4-6, save as txt.
Open text-editor, reconvert comma to decimal-point, save file as asc.
Import asc in FC.
Problems:
The text-editor needs a while to replace points/commas in such a huge file.
My Excel decimates the txt-file, I cannot load more than approx. 1 mio lines
For a technical documentation the original scan is far too rough.
FC places the point-cloud kilometers away from the origin depending on drone-GPS.
As far as I understood some Youtube posts on Recap, there is the possibility to upload the point-cloud data to the Autodesk cloud (after creating a user-account). They can produce a mesh for downloading and using in CAD.
But is that good way for sensible data? (Often there are antennas from the government/military at the towers and this is classified data…)
Installing Trails/Geodata-workbenches:
Which github-link is “valid”?
Where must I put the pivy-tracker?
(the addon-manager does not work on my company-laptop, no idea why. Maybe the virus scanner…)
https://github.com/HakanSeven12/FreeCAD ... -Workbench
https://github.com/joelgraff/freecad.trails
https://github.com/joelgraff/pivy_trackers
My system:
OS: Windows 10 (10.0)
Version: 0.19.20980 (Git)
Hash: c2818d9159385d23b182dc7167af2d4bacbee94c
Python version: 3.6.8
Qt version: 5.12.1
HakanSeven12
Postby HakanSeven12 » Sat Jun 20, 2020 9:07 am
You can import pts files direcly by using trails. Its support column defination and multiple delimeters(comma,space,tab).
links:
https://github.com/joelgraff/freecad_python_support
Must be like this
Mod
  |_  Trails
           |_ freecad_python_support
           |_ pivy_trackers
But there is some bug at pivy trackers so maybe you need to wait untill this PR merged.
https://github.com/joelgraff/pivy_trackers/pull/22
jeno
Postby jeno » Sat Jun 20, 2020 10:10 am
My Workflow:
Problems:
As mentioned in my first post Meshlab is afaik able to open pts-files. By the way column 4 to 6 is RGB. Sometimes you can find 7 columns. Then column 4 is intensity, a value for the quality of the reflected beam compared to the sent.
In Meshlab you are able to import the point cloud, edit the points (delete and also translate) and mesh it.
Maybe you give it a try as long as trails do not work for you.
cheers
Postby Kunda1 » Sun Jun 21, 2020 10:32 am
Per @HakanSeven12 answer the below solutions are superfluous, but FWIW
You may just be able to automate these steps with python especially a library called pandas.
converting decimal to comma can be done with 1 line of code:
df = pd.read_csv(r'data.csv', decimal=',')
source https://stackoverflow.com/a/34315381
Removing parts of excel files without opening them can also be done with Pandas:
https://www.geeksforgeeks.org/python-de ... ndas-drop/
